    Phone Notifications
    97 Posts 31 Posters 161.6k Views 33 Watching
    • G Offline
      gismo2006
      Hmm,
      I have the same Problem… :-)
      Does anybody know, where the mistake is?
      Greets gismo2006
      • G Offline
        gismo2006
        Yeah! :-)
        If you look in my last post you can read that i have the same problem like the post before. Yesterday evening i remember myself at scool time and the computer lessons. I remember there was diffrent editors which will help to manage your code. But the important feature was the code check option. so i copy the code of phone_notification.js in a editor and press the check button. (It will be found in modules/phone_notification) And the editor display me some error. There was an missing In line 123 (console.log("display icon: "); ) I have edit this, then saving the file an everythink works fine.
        I hope that will help you.
        Sorry for my bad englich :-) I hope you can understand…
        Greets gismo2006
        R 1 Reply Last reply Reply Quote 3
        • cowboysdudeC Offline
          cowboysdude Module Developer
          Great work Gismo!!! :)
            ronny3050 Module Developer @gismo2006
            @gismo2006 Excellent work gismo! I made that mistake on my last push. I have updated the module. Thank you :D
            • G Offline
              gismo2006
              Hi, thank you for your praise.
              But the really excelent work you are doing. @ronny3050 I think there was some more mistake too… If i paste the missing " the module will displayed correctly but it won´t regonize notifications. Some post before my post, moosedookie post a link to github. I now copy this files and the module work correctly.
              I´m now thinking about your email module :-)
              Greets gismo2006
              R 1 Reply Last reply Reply Quote 2
                @gismo2006 Thank you once more for finding the bug! I am not sure why moosedookie’s link works. I’ll compare the two and let you know.
                Please do try it :D
                  Stupid Iphone LOL
                  • G Offline
                    gismo2006
                    @cowboysdude Hi, sorry i didn’t understand your last post. I’m not using a Iphone… :-)
                    cowboysdudeC 1 Reply Last reply Reply Quote 1
                      cowboysdude Module Developer @gismo2006
                      @gismo2006 said in Phone Notifications:
                      I know it’s not your fault. They are just not willing to make it easy to people who own them because they want to control the ecosystem…
                      • L Offline
                        Les
                        When should notifications appear? Because MM just says “No New Notifications”
                        I signed up for a pushbutton account. Went to setting generated my api key. installed pushbutton module. ran npm install. then added the following to my config.js
                                                module: 'phone_notification',
                                                position: 'bottom_right',
                                                header: 'Xperia Z3',
                                                        accessToken: 'o.XXXX$',
                                                        numberOfNotifications: 5,
                                                        displayNotificationIcon: true,
                                                        displayMessage: true,
                                                        displayCount: true,
                                                        alert: true,
                                                        fade: true,
                                                        maxCharacters: 50
                        Really all I want to do is display an incoming call (don’t care about historical, although I can see them in ppushbucket… An help would be appreciated.
                        Note from admin: Please use Markdown on code snippets for easier reading!
                        • W Offline
                          willharwell @Les
                          @Les
                          Having the same issue here.
                          From the command line where I started npm I see nop nop nop push, each time a notification comes in.
                          • G Offline
                            gismo2006
                            I’ve got the same Problem some time ago. I didn’t know where the Problem is, but I can explain you @Les and @willharwell what I have done and it works fine at my mirror.
                            At first I have sing up at phushbellt Then I have installed like the Readme file says.
                            BUT then no notification will displayed. After spending hour for hour i opend the Link of moosedookie some post before and manually download the notification.js from this Link. Then I copy and overwrite it in the module Folder at my Raspberry.
                            And now everything works fine. For example If I push “test notification” in the Handy app, it will displayed directly.
                            I hope you understand…
                            greets gismo
                              @willharwell and @Les can you please try the latest push and let me know? I hope it will fix the issue.
                              • N Offline
                                nobita @ronny3050
                                @ronny3050 said in Phone Notifications:
                                How to Update your module
                                  ronny3050 Module Developer @nobita
                                  @nobita call ‘git pull’ in the phone_notification directory.
                                  • G Offline
                                    guybatt234
                                    Has there been any progress in making notifications time out?
                                      mschlesinger19
                                      @guybatt234 I am not sure if the fix was ever put in for reversing the order but I figured out how to reverse the order of notifications. In phone_notification.js in the cleanPayload function instead of pushing to the back of the array just call a payload.unshift(newPayload) and that should treat it like a stack and not a queue
                                      • T Offline
                                        Toast
                                        im on the latest revision but not receiving any notifcations
                                        • L Offline
                                          lucallmon
                                          Has anyone had an issue with filling up your notifications and then no new notifications come through at all?
                                          • rchaseR Offline
                                            rchase
                                            Anyone ever get iphone work?
                                            • 3 / 5
