    Can't get weatherforecast to work
    2 Posts 2 Posters 2.2k Views 2 Watching
    • Z Offline
      Zooooooom
      I finally got my magic mirror built and mounted. But, the weather forecast module isn’t working. The current weather module works just fine, but the forecast isn’t loading. Any ideas? Here’s my config.js file
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check-o ",
      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "4363990",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "59540................."
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "59540........."
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
        Mykle1 Project Sponsor Module Developer @Zooooooom
        @Zooooooom
        Look at this topic. There seems to a few people experiencing the same thing.
        https://forum.magicmirror.builders/topic/4781/problem-with-weather-forecast
