    Problem with Weather forecast
    47 Posts 14 Posters 48.4k Views 13 Watching
      Aurelsam
      Hello!
      I have a problem with weather forecast.
      He doesn’t appear on the screen, is there a manipulation to do ?
        Mykle1 Project Sponsor Module Developer @Aurelsam
        @Aurelsam
        You’re not giving a lot of information here. Have you followed the instructions in the README?
          Aurelsam
          Yes i have read everything, i have written the same information as for the current wheater module. But nothing appears…
            @Aurelsam
            Post your config here
              Aurelsam @Mykle1
              @Mykle1
              module: “weatherforecast”,
              position: “top_right”,
              locationID: “2979752”, //ID from http://www.openweathermap.org/help/city_list.txt
              appid: “ea0222cc89779d1aXXXXXXXXXXXXXXX”,
              maxNumberOfDays: “4”
                @Aurelsam said in Problem with Weather forecast:
                This works for me. Check your appid.
                	module: "weatherforecast",
                	header: "Saint-Germain-les-Corbeil,France",
                		locationID: "2979752", //ID from http://www.openweathermap.org/help/city_list.txt
                		appid: "ea0222cc89779d1aXXXXXXXXXXXXXXX",
                		maxNumberOfDays: "4"
                  Aurelsam @Mykle1
                  @Mykle1
                  My appid is good because it works with the current weather.
                  There are no other solutions?
                  Thx Mykle1
                    @Aurelsam
                    Copy and paste my config entry above into your config and DOUBLE CHECK your appid. That entry is working.
                    EDIT! Working under MM 2.1.1
                      Sp4M
                      I have the same problem, even after deep investigations.
                      I can get current weather calling this :
                      http://api.openweathermap.org/data/2.5/weather?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
                      I can get forecast weather with 3h timepoints using
                      http://api.openweathermap.org/data/2.5/forecast?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
                      BUT i cannot use daily forecast which is used by MM
                      http://api.openweathermap.org/data/2.5/forecast/daily?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
                      it returns : {“cod”:401, “message”: “Invalid API key. Please see http://openweathermap.org/faq#error401 for more info.”}
                      it appears that daily forecast is not free (anymore ?) regarding openweather website.
                      https://openweathermap.org/price
                      Maybe it is a problem related to location ? I see that I actualy live just a few kilometers away from Aurelsam (Saint-Germain-les-Corbeil, France)
                        Sp4M
                        You can temporarly get around the problem by using 3h steps forecast (2nd link of my previous post) instead of daily, and by adding this to the weatherforecast.js :
                        in function processWeather,
                        after line var forecast = data.list[i];
                        add:
                        if (forecast.dt_txt.split(" ")[1] != “00:00:00”) continue;
                        (in config)
                        maxNumberOfDays parameter now counts timepoints (each 3h) and not days:
                        maxNumberOfDays: 4 // means 4 forecast points: 0h, 3h, 6h, 9h
                        maxNumberOfDays: 8 // means 8 timepoints of 3h = 24h = 1 day
                        maxNumberOfDays: 40 // means 40 timepoints of 3h = 120h = 5 days
                        You should also remove parameter check in the same script weatherforecast.js, which allow maximum 16 (for 16 days). it should be set to maximum 128 (timepoints) for 16 days.
                        example:
                        params += “&cnt=” + (((this.config.maxNumberOfDays < 1) || (this.config.maxNumberOfDays > 128)) ? 40 : this.config.maxNumberOfDays);
                          Mykle1 Project Sponsor Module Developer @Mykle1
                          @Mykle1 said in Problem with Weather forecast:
                          I don’t know what to tell you. That entry is working.
                          Reply to myself! LOL
                          An oversight on my part. I was testing that in MM 2.1.1 and it WAS working. I just moved to MM 2.1.2 and it does NOT
                          • P Offline
                            plybz18
                            Same problem here, for weatherforecast it shows incorrect appid, but same appid is working for current weather.!!!
                              Aurelsam @Mykle1
                              @Mykle1
                              So it means that it does not work with the latest version ??
                              How do you install 2.1.1?
                                It would appear so. You could try the workaround that @SP4M provided above. I have not tried it.
                                https://github.com/MichMich/MagicMirror/releases
                                  Sp4M @Mykle1
                                  I did. It works with additionnal calculations if you want to use temperatures - you have to average all temperatures (min and max) from all 3h timepoints of one day.
                                  By the way, it’s less precise than real min and max of the day …
                                  @Mykle1 : how could it be a problem of MM version if openweather does not recognize “forecast/daily” in its url in your opinion ? I should have missed something
                                  Mykle1M 2 Replies Last reply Reply Quote 0
                                    Mykle1 Project Sponsor Module Developer @Sp4M
                                    @Sp4M said in Problem with Weather forecast:
                                    Honestly, I don’t know. What I DO know is my appid was being rejected under MM 2.1.2, as reported by the console. Went back to 2.1.1 and the appid is accepted normally. I didn’t investigate any further. Perhaps something in the way the request is being made? I just don’t know.
                                      Well, I just moved to the develop branch, and although the unauthorized appid error is gone, weatherforecast still won’t work, and a new error is reported. The module simply stays on “Loading . . .”
                                      0_1504656609763_dev.JPG 0_1504656628065_dev error.JPG 0_1504656640984_dev loading.JPG
                                      ? 2 Replies Last reply Reply Quote 0
                                      • ? Offline
                                        A Former User @Mykle1
                                        @Mykle1 I dont know about rhis module, but youd better to see scale field in config. I guess it is missed or invalid.
                                        • ? Offline
                                          @Mykle1 I read dev codes now, scale is not documented yet.(and it has also defined wrongly in defaults.)
                                          Maybe scale:"c" or scale:"f" may work.
                                          • L Offline
                                            luizcarlosnery
                                            Same personal problem.
                                            Mm2 does not display the Weatherforecast on the screen.
                                            • 1 / 3
