    Problem with Weather forecast
    47 Posts 14 Posters 43.3k Views 13 Watching
      Aurelsam
      Hello!
      I have a problem with weather forecast.
      He doesn’t appear on the screen, is there a manipulation to do ?
        Mykle1 Project Sponsor Module Developer @Aurelsam
        @Aurelsam
        You’re not giving a lot of information here. Have you followed the instructions in the README?
          Aurelsam
          Yes i have read everything, i have written the same information as for the current wheater module. But nothing appears…
            @Aurelsam
            Post your config here
              Aurelsam @Mykle1
              @Mykle1
              module: “weatherforecast”,
              position: “top_right”,
              locationID: “2979752”, //ID from http://www.openweathermap.org/help/city_list.txt
              appid: “ea0222cc89779d1aXXXXXXXXXXXXXXX”,
              maxNumberOfDays: “4”
                @Aurelsam said in Problem with Weather forecast:
                This works for me. Check your appid.
                	module: "weatherforecast",
                	header: "Saint-Germain-les-Corbeil,France",
                		locationID: "2979752", //ID from http://www.openweathermap.org/help/city_list.txt
                		appid: "ea0222cc89779d1aXXXXXXXXXXXXXXX",
                		maxNumberOfDays: "4"
                  Aurelsam @Mykle1
                  @Mykle1
                  My appid is good because it works with the current weather.
                  There are no other solutions?
                  Thx Mykle1
                    @Aurelsam
                    Copy and paste my config entry above into your config and DOUBLE CHECK your appid. That entry is working.
                    EDIT! Working under MM 2.1.1
                      Sp4M
                      I have the same problem, even after deep investigations.
                      I can get current weather calling this :
                      http://api.openweathermap.org/data/2.5/weather?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
                      I can get forecast weather with 3h timepoints using
                      http://api.openweathermap.org/data/2.5/forecast?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
                      BUT i cannot use daily forecast which is used by MM
                      http://api.openweathermap.org/data/2.5/forecast/daily?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
                      it returns : {“cod”:401, “message”: “Invalid API key. Please see http://openweathermap.org/faq#error401 for more info.”}
                      it appears that daily forecast is not free (anymore ?) regarding openweather website.
                      https://openweathermap.org/price
                      Maybe it is a problem related to location ? I see that I actualy live just a few kilometers away from Aurelsam (Saint-Germain-les-Corbeil, France)
                        Sp4M
                        You can temporarly get around the problem by using 3h steps forecast (2nd link of my previous post) instead of daily, and by adding this to the weatherforecast.js :
                        in function processWeather,
                        after line var forecast = data.list[i];
                        add:
                        if (forecast.dt_txt.split(" ")[1] != “00:00:00”) continue;
                        (in config)
                        maxNumberOfDays parameter now counts timepoints (each 3h) and not days:
                        maxNumberOfDays: 4 // means 4 forecast points: 0h, 3h, 6h, 9h
                        maxNumberOfDays: 8 // means 8 timepoints of 3h = 24h = 1 day
                        maxNumberOfDays: 40 // means 40 timepoints of 3h = 120h = 5 days
                        You should also remove parameter check in the same script weatherforecast.js, which allow maximum 16 (for 16 days). it should be set to maximum 128 (timepoints) for 16 days.
                        example:
                        params += “&cnt=” + (((this.config.maxNumberOfDays < 1) || (this.config.maxNumberOfDays > 128)) ? 40 : this.config.maxNumberOfDays);
                        • 1 / 5
