    Problem with Weather forecast
    47 Posts 14 Posters 43.0k Views 13 Watching
      Mykle1 Project Sponsor Module Developer @Aurelsam
      @Aurelsam said in Problem with Weather forecast:
      module: “weatherforecast”,
      position: “top_right”,
      locationID: “2979752”, //ID from http://www.openweathermap.org/help/city_list.txt
      appid: “ea0222cc89779d1aXXXXXXXXXXXXXXX”,
      maxNumberOfDays: “4”
      This works for me. Check your appid.
      	module: "weatherforecast",
      	header: "Saint-Germain-les-Corbeil,France",
      		locationID: "2979752", //ID from http://www.openweathermap.org/help/city_list.txt
      		appid: "ea0222cc89779d1aXXXXXXXXXXXXXXX",
      		maxNumberOfDays: "4"
        Aurelsam @Mykle1
        @Mykle1
        My appid is good because it works with the current weather.
        There are no other solutions?
        Thx Mykle1
          @Aurelsam
          Copy and paste my config entry above into your config and DOUBLE CHECK your appid. That entry is working.
          EDIT! Working under MM 2.1.1
            Sp4M
            I have the same problem, even after deep investigations.
            I can get current weather calling this :
            http://api.openweathermap.org/data/2.5/weather?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
            I can get forecast weather with 3h timepoints using
            http://api.openweathermap.org/data/2.5/forecast?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
            BUT i cannot use daily forecast which is used by MM
            http://api.openweathermap.org/data/2.5/forecast/daily?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
            it returns : {“cod”:401, “message”: “Invalid API key. Please see http://openweathermap.org/faq#error401 for more info.”}
            it appears that daily forecast is not free (anymore ?) regarding openweather website.
            https://openweathermap.org/price
            Maybe it is a problem related to location ? I see that I actualy live just a few kilometers away from Aurelsam (Saint-Germain-les-Corbeil, France)
              Sp4M
              You can temporarly get around the problem by using 3h steps forecast (2nd link of my previous post) instead of daily, and by adding this to the weatherforecast.js :
              in function processWeather,
              after line var forecast = data.list[i];
              add:
              if (forecast.dt_txt.split(" ")[1] != “00:00:00”) continue;
              (in config)
              maxNumberOfDays parameter now counts timepoints (each 3h) and not days:
              maxNumberOfDays: 4 // means 4 forecast points: 0h, 3h, 6h, 9h
              maxNumberOfDays: 8 // means 8 timepoints of 3h = 24h = 1 day
              maxNumberOfDays: 40 // means 40 timepoints of 3h = 120h = 5 days
              You should also remove parameter check in the same script weatherforecast.js, which allow maximum 16 (for 16 days). it should be set to maximum 128 (timepoints) for 16 days.
              example:
              params += “&cnt=” + (((this.config.maxNumberOfDays < 1) || (this.config.maxNumberOfDays > 128)) ? 40 : this.config.maxNumberOfDays);
                Mykle1 Project Sponsor Module Developer @Mykle1
                @Mykle1 said in Problem with Weather forecast:
                I don’t know what to tell you. That entry is working.
                Reply to myself! LOL
                An oversight on my part. I was testing that in MM 2.1.1 and it WAS working. I just moved to MM 2.1.2 and it does NOT
                  plybz18
                  Same problem here, for weatherforecast it shows incorrect appid, but same appid is working for current weather.!!!
                    Aurelsam @Mykle1
                    @Mykle1
                    So it means that it does not work with the latest version ??
                    How do you install 2.1.1?
                      It would appear so. You could try the workaround that @SP4M provided above. I have not tried it.
                      https://github.com/MichMich/MagicMirror/releases
                        Sp4M @Mykle1
                        I did. It works with additionnal calculations if you want to use temperatures - you have to average all temperatures (min and max) from all 3h timepoints of one day.
                        By the way, it’s less precise than real min and max of the day …
                        @Mykle1 : how could it be a problem of MM version if openweather does not recognize “forecast/daily” in its url in your opinion ? I should have missed something
                        • 1 / 5
