    Problem with Weather forecast
    47 Posts 14 Posters 47.5k Views 13 Watching
      Mykle1 Project Sponsor Module Developer @Aurelsam
      @Aurelsam
      Copy and paste my config entry above into your config and DOUBLE CHECK your appid. That entry is working.
      EDIT! Working under MM 2.1.1
        Sp4M
        I have the same problem, even after deep investigations.
        I can get current weather calling this :
        http://api.openweathermap.org/data/2.5/weather?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
        I can get forecast weather with 3h timepoints using
        http://api.openweathermap.org/data/2.5/forecast?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
        BUT i cannot use daily forecast which is used by MM
        http://api.openweathermap.org/data/2.5/forecast/daily?q=paris&units=metric&APPID=cbbxxxxxxxxxxxxxx
        it returns : {“cod”:401, “message”: “Invalid API key. Please see http://openweathermap.org/faq#error401 for more info.”}
        it appears that daily forecast is not free (anymore ?) regarding openweather website.
        https://openweathermap.org/price
        Maybe it is a problem related to location ? I see that I actualy live just a few kilometers away from Aurelsam (Saint-Germain-les-Corbeil, France)
          Sp4M
          You can temporarly get around the problem by using 3h steps forecast (2nd link of my previous post) instead of daily, and by adding this to the weatherforecast.js :
          in function processWeather,
          after line var forecast = data.list[i];
          add:
          if (forecast.dt_txt.split(" ")[1] != “00:00:00”) continue;
          (in config)
          maxNumberOfDays parameter now counts timepoints (each 3h) and not days:
          maxNumberOfDays: 4 // means 4 forecast points: 0h, 3h, 6h, 9h
          maxNumberOfDays: 8 // means 8 timepoints of 3h = 24h = 1 day
          maxNumberOfDays: 40 // means 40 timepoints of 3h = 120h = 5 days
          You should also remove parameter check in the same script weatherforecast.js, which allow maximum 16 (for 16 days). it should be set to maximum 128 (timepoints) for 16 days.
          example:
          params += “&cnt=” + (((this.config.maxNumberOfDays < 1) || (this.config.maxNumberOfDays > 128)) ? 40 : this.config.maxNumberOfDays);
            Mykle1 Project Sponsor Module Developer @Mykle1
            @Mykle1 said in Problem with Weather forecast:
            I don’t know what to tell you. That entry is working.
            Reply to myself! LOL
            An oversight on my part. I was testing that in MM 2.1.1 and it WAS working. I just moved to MM 2.1.2 and it does NOT
              plybz18
              Same problem here, for weatherforecast it shows incorrect appid, but same appid is working for current weather.!!!
                Aurelsam @Mykle1
                @Mykle1
                So it means that it does not work with the latest version ??
                How do you install 2.1.1?
                  @Aurelsam said in Problem with Weather forecast:
                  It would appear so. You could try the workaround that @SP4M provided above. I have not tried it.
                  https://github.com/MichMich/MagicMirror/releases
                    Sp4M @Mykle1
                    I did. It works with additionnal calculations if you want to use temperatures - you have to average all temperatures (min and max) from all 3h timepoints of one day.
                    By the way, it’s less precise than real min and max of the day …
                    @Mykle1 : how could it be a problem of MM version if openweather does not recognize “forecast/daily” in its url in your opinion ? I should have missed something
                      Mykle1 Project Sponsor Module Developer @Sp4M
                      @Sp4M said in Problem with Weather forecast:
                      Honestly, I don’t know. What I DO know is my appid was being rejected under MM 2.1.2, as reported by the console. Went back to 2.1.1 and the appid is accepted normally. I didn’t investigate any further. Perhaps something in the way the request is being made? I just don’t know.
                        Well, I just moved to the develop branch, and although the unauthorized appid error is gone, weatherforecast still won’t work, and a new error is reported. The module simply stays on “Loading . . .”
                        0_1504656609763_dev.JPG 0_1504656628065_dev error.JPG 0_1504656640984_dev loading.JPG
                          [[global:former-user]] @Mykle1
                          @Mykle1 I dont know about rhis module, but youd better to see scale field in config. I guess it is missed or invalid.
                            @Mykle1 I read dev codes now, scale is not documented yet.(and it has also defined wrongly in defaults.)
                            Maybe scale:"c" or scale:"f" may work.
                            • L Offline
                              luizcarlosnery
                              Same personal problem.
                              Mm2 does not display the Weatherforecast on the screen.
                                Mykle1 Project Sponsor Module Developer @luizcarlosnery
                                @luizcarlosnery
                                There’s a problem with Openweather’s api not accepting certain api keys. In the meantime, you could try another weather module. There are many.
                                Scroll down to the weather category
                                https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules#3rd-party-modules
                                  roramirez Core Contributors @Mykle1
                                  Well… Yesterday I submitted a patch to hack the situation with the new accounts in OpenWeather.
                                  If you can test it will be great!
                                  https://github.com/roramirez/MagicMirror/commit/e8438d37d78acc7a9e29e694a6987ce068324bcd
                                  • L Offline
                                    luizcarlosnery
                                    Hi Roramirez, brother, it worked! but the day of the week, which should show “Monday” “Tuesday” “Wednesday” … shows everyone how “Sunday” to solve?
                                    Thank you so much…
                                    • F Offline
                                      frank61BS @roramirez
                                      @roramirez
                                      Hello Ramirez, I had the same problem. But with your patch I can see the weatherforeast now
                                      Thanks Frank
                                      • AzraelA Offline
                                        Azrael
                                        Hello, I have exactly the same problem and I am trying to use your patch Ramirez. However, I am coming from the “mechanical world” and I’m new to Linux and GitHub. Could any of you write me how to apply such a patch?
                                          Mykle1 Project Sponsor Module Developer @Azrael
                                          @Azrael said in Problem with Weather forecast:
                                          You have to edit your weatherforecast.js file. Go to the link for the fix. The line you see highlighted in RED has to be removed (or commented out) of your weatherforecast.js file. The lines you see highlighted in GREEN have to be added in your weatherforecast.js file. The line numbers on the left make it easy for you to find exactly where the edits belong.
                                          • AzraelA Offline
                                            Azrael
                                            Thank you Mykle1. Now the weather forecast shows up where it should be.
                                            However, I have exactly the same problem what luizcarlosnery mentioned earlier. Today (Saturday) I see: Sat,Sat,Sat,Sat,Sat,Sun,Sun.
