    Motion Detector
    213 Posts 38 Posters 571.7k Views 39 Watching
    • T Offline
      trividar
      Thank you guys for having a look!!
        alexyak @trividar
        @trividar before I spend some time creating a dev branch, could you please run the magic mirror from the terminal on RPI with the following command line:
        npm start dev
        The magic mirror will be started with dev tools enabled. Switch to the 'Console" tab in the dev tools and you should be able to see the following output:
        “compare result=Infinity,Infinity;0,0” when there’s no movement before your camera and something like “compare result=49,44;31,47” when there’s some movement.
        Also if you could also look for errors in this console as well (red colored lines).
        • cowboysdudeC Offline
          cowboysdude Module Developer
          For me the I get the compare result=Infinity,Infinity:0,0 but it’s not sensing any movement… so it’s the camera that’s the problem here…
          I did get an error its says:
          NavigatorUserMediaError {name: "DeviceNotFoundError", message "", constaintName: ""}
          That tells me it can’t access the camera…
          How does one fix that?
            alexyak @cowboysdude
            @cowboysdude this is what I had suspected. What kind of camera do you have? Web camera over usb?
            • T Offline
              trividar
              I use the pi NoIR camera V1. Sorry for the bad image!
              • strawberry 3.141S Offline
                this sounds that your cam is not getting recognized as a valid webcam
                  cowboysdude Module Developer @strawberry 3.141
                  @strawberry-3.141 said in Motion Detector:
                  I am using the NOIR Picamera that’s interesting because outside the module the camera works fine LOL
                  Hummmmmmm…
                    can you guys try sudo modprobe bcm2835-v4l2 in the console before starting the mirror
                    • T Offline
                      trividar
                      I got this error:
                        strange this is the driver for the camera module
                        do you have enabled the camera module?
                        • T Offline
                          trividar
                          Yes I have… And the camera works, i can take picutres abd see live pictures.
                            then it’s really strange that you can’t find the driver, did you wrote v412 or v4l2 ?
                            looks like you typed 1 but it should be a lowercase L
                            • T Offline
                              trividar
                              This post is deleted!
                              • T Offline
                                trividar
                                Now It works… juhuuuuuuuuuuu;o) My monitor turn off… and recognize motion and turns on. In dev Mode i see now also motions!
                                  hopefully this works for @cowboysdude as well
                                    I just typed in the sudo modprobe bcm2835-v4l2 and it returned nothing so I’m guessing that’s a good thing LOL
                                      So this is what I’ve done and it solved it…
                                      I took your sudo modprobe bcm2835-v4l2 and entered before I started the mirror and no more error so I started the mirror in dev and it was registering movement…Great!
                                      So I closed the mirror and restarted… same error, driver not loaded…
                                      so I did this in case of a power out,e tc…in a terminal window:
                                      sudo crontab -e
                                      Enter this on the last line:
                                      @reboot sudo modprobe bcm2835-v4l2
                                      Saved and exited.
                                      Reboot
                                      Restart mirror in dev mode
                                      NO error and tracks movement
                                      close mirror and restart in dev
                                      NO error and tracks movement.
                                      PROBLEM SOLVED!! Thank you guys for being patient!! It’s working.
                                      • T Offline
                                        trividar
                                        Thank you guys! you are amazing!
                                          sero
                                          Same here, works like a charm!
                                          Thanks guys :)
                                            alexyak
                                            Huge thank you to @strawberry-3-141 for helping to troubleshoot this issue and suggesting the solution! While I know all kinds of dev languages and tools, I am pretty new RPI and Linux.
                                            • 10
                                            • 11
                                            • 3 / 11
