    Motion Detector
    213 Posts 38 Posters 546.9k Views 39 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @done
      @done said in Motion Detector:
      @strawberry-3.141 Ok, I’ll give it a try. Tomorrow morning, I will test again. Thx!
      WORST case senario is you install a screen saver program and disable it… period. :)
        bibi @cowboysdude
        @cowboysdude 1st thx for taking time to reply. much appriciated! the PIR is ok but as it needs to get hidden somewhere, etc it’s less convinent. Yes you are right, the solution depends on my personnal need… i just need a way to switch on MM when i am in front of it BUT also completly switch off the monitor when nothing detected and not only the MM.
        oh great, i will check @strawberry-3-141 module for sure!
        @IngmarSwart also designed a solution with motion detection with a Picam behind the glass which seems to be nice to. i let you check it if interest…
        by the way, do i have to remove Paviro module to install your one?
        i couldn’t find @strawberry-3-141 module… can you pls forward me the link?
        • bheplerB Offline
          bhepler Module Developer @strawberry 3.141
          @strawberry-3.141 said in Motion Detector:
          @done propably everything is working for you guys and you can just see the screensaver, be sure to disable the screensaver
          Negative. The screensaver has been disabled but the motiondetection module isn’t working. I gave the Facial Recognition module a try, but with the camera behind the glass, there isn’t enough light to train the system to recognize anyone.
          At this point, I’m considering downgrading my chromium to something without the new security “features”.
          • bheplerB Offline
            I’m still working this problem. To help with @paphko 's concern about processor utilization, I finally figured out how and where to put a delay in the main image comparison loop. @alexyak is using the RequestAnimationFrame feature to run the comparison as fast as the browser can render the UI.
            If you wish to include a delay, modify your motion.js file’s main function to read as such:
            function main(frequency) {
            	render();
            	if(rendering == true) {
            		setTimeout(function() {
            			raf(main.bind(this));
            		}, 500);
            That last number (the 500) is the milliseconds between each image comparison. I think half a second between comparisons is enough to keep the CPU usage down and the effectiveness up.
              done @bhepler
              Thx @bhepler
              this helped to reduce my temperature from 80 °C to 50-60 °C.
              Maybe the 80 °C even caused the wake up problem? :)
              Anyway, I think I’ll try the voice activation module tomorrow.
              Somehow it’s even very sweet to say “Mirror, Mirror on the wall. Wake up!”.
                DirkS
                That is the reason why my screen doesn’t switch on after a couple of hrs switched off.
                Any idea what the cause of unavailable tvservice is?
                Testwise i used the scripts reported here before. They where called if a PIR detects motion or no motion.
                Nov  1 08:22:00 MagicMirror kernel: [86411.138649] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                Nov  1 08:22:00 MagicMirror kernel: [86411.138665] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                Nov  1 08:22:00 MagicMirror kernel: [86411.138670] detected fb_set_par error, error code: -22
                Nov  1 08:22:00 MagicMirror kernel: [86411.139138] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                Nov  1 08:22:00 MagicMirror kernel: [86411.139148] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                Nov  1 08:22:00 MagicMirror kernel: [86411.139152] detected fb_set_par error, error code: -22
                Nov  1 08:22:00 MagicMirror kernel: [86411.140642] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                Nov  1 08:22:00 MagicMirror kernel: [86411.140654] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                Nov  1 08:22:00 MagicMirror kernel: [86411.140659] detected fb_set_par error, error code: -22
                Nov  1 08:22:00 MagicMirror kernel: [86411.140777] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                Nov  1 08:22:00 MagicMirror kernel: [86411.140785] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                Nov  1 08:22:00 MagicMirror kernel: [86411.140789] detected fb_set_par error, error code: -22
                Nov  1 08:22:00 MagicMirror kernel: [86411.140856] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                Nov  1 08:22:00 MagicMirror kernel: [86411.140863] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                Nov  1 08:22:00 MagicMirror kernel: [86411.140868] bcm2708_fb_pan_display(0,0) returns=-22
                Nov  1 08:22:00 MagicMirror systemd[1]: Started Getty on tty6.
                Nov  1 08:22:00 MagicMirror kernel: [86411.256398] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                Nov  1 08:22:00 MagicMirror kernel: [86411.256413] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                Nov  1 08:22:00 MagicMirror kernel: [86411.256418] detected fb_set_par error, error code: -22
                Nov  1 08:22:00 MagicMirror kernel: [86411.256758] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                Nov  1 08:22:00 MagicMirror kernel: [86411.256770] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                Nov  1 08:22:00 MagicMirror kernel: [86411.256775] bcm2708_fb_pan_display(0,0) returns=-22
                Nov  1 08:22:00 MagicMirror kernel: [86411.296428] raspberrypi-firmware soc:firmware: Request 0x00040002 returned status 0x80000001
                Nov  1 08:22:00 MagicMirror kernel: [86411.296455] bcm2708_fb soc:fb: bcm2708_fb_blank(0) failed: -22
                2016.11.01 08:05:04 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_off.sh &")}: -1
                tvservice-client: Failed to connect to TV service: -1
                [E] Failed to power off HDMI
                Powering off HDMI
                2016.11.01 08:05:57 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_on.sh &")}: -1
                [E] Failed to set property 4
                2016.11.01 08:07:37 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_off.sh &")}: -1
                Powering off HDMI
                2016.11.01 08:09:00 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_on.sh &")}: -1
                2016.11.01 08:09:42 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_off.sh &")}: -1
                Powering off HDMI
                2016.11.01 08:09:59 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_on.sh &")}: -1
                ping: icmp open socket: Operation not permitted
                2016.11.01 08:10:41 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_off.sh &")}: -1
                Powering off HDMI
                2016.11.01 08:21:59 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_on.sh &")}: -1
                2016.11.01 08:22:50 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_off.sh &")}: -1
                Powering off HDMI
                  DirkS
                  So here i found a workaround. Maybe it fixes the issue but let’s see. I just modified my test script and need to see it the next hrs/days
                  https://github.com/raspberrypi/documentation/pull/245/files
                  https://github.com/raspberrypi/linux/issues/487
                    DirkS
                    for all the people here I wrote it more cleary :D
                    i had big problems by switching off my screen with the PIR or another module with camera. The problem was not the module itself it is a firmware problem of the PI. I could see the same problem outside of MagicMirror as well by trying different things.
                    Reported also here:
                    The symptom is that after a while of switching on and off the screen it remains off.
                    Dmesg reports the problem:
                    Switching off the screen with
                    /opt/vc/bin/tvservice -o
                    and on with
                    /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chat 7
                    does not work reliable! The git issue tells you more about.
                    The workaround is a not yet described solution inside the config.txt
                    the option “hdmi_blanking=1” is your friend in this case! :D
                    Now i’m switching off the screen with
                    vcgencmd display_power 0
                    and on with
                    vcgencmd display_power 1
                    And it is working now like a charm! Did started to use it one day before this report and it is still working without any issue :)
                    Honestly speaking i don’t use any MM module for switching off anymore. But maybe my discovered solution will help any other and might be a way to change the module as well.
                    If you have trouble with on/off as well please check the output of dmesg. If you have the frambuffer problem you can fix it.
                    My personal solution is to have the PIR state at FHEM and from FHEM i’m using a script to switch the screen. But that’s a special case and for the most people here the usage of a MM Module will be the better way.
                    regards
                    Dirk
                    B D 2 Replies Last reply Reply Quote 2
                      bibi @DirkS
                      @DirkS thx for sharing! one question please : where is located the option : “hdmi_blanking=1” ???
                      • bheplerB Offline
                        bhepler Module Developer @bibi
                        @bibi Based on that pull request, it looks like it’s in the config.txt of your Pi. So /boot/config.txt
                          DirkS
                          @bibi yes you need to include it into /boot/config.txt
                            bibi @DirkS
                            @Dirks Thx!
                            @bhepler Thx! i will add this option there under HDMI hotplug as i don’t know where else to add.
                              bibi @bhepler
                              @bhepler and @DirkS : any idea why my screen doesn’t stay off as long as no motion is detected??
                                done @DirkS
                                @DirkS Thank you. Pi doesn’t die over nights :D
                                But before I mess it up:
                                Would the motion detection with the common script work or not?
                                How did you realize it? Where did you enter your new script?
                                And don’t you want to make an additional motion detector module for those who have the same problem? :)
                                I don’t see the original programmer caring to much. ;)
                                cheers
                                done
                                  DirkS
                                  @done as discribed above by @cpramhofer (thanks to you :) ) i created the monitor_on and off.sh script.
                                  With FHEM i’m polling the PIR status and use a DOIF to call on or off. Because my homeautomation depends in FHEM i have much more control instead of using a MM module, i switch much more devices with the PIR as well. I have several Pi’s with FHEM installed so it is also on the PI for the Mirror.
                                    DirkS
                                    @bib you are providing a bit less information to give you some tipp.
                                    B 2 Replies Last reply Reply Quote 0
                                      bibi @DirkS
                                      @DirkS ok here you go. 1st: when the Pi is started the screen directly goes into sleep. it’s a bit annoying but i can live with that as i will not reboot it everyday. 2nd: to wake up the system with a motion during this sleep mode, it takes quite a while (don’t know why) 3rd: when motion is detected, screen wakes up and stays up accordingly the time defined in config.js and goes sleep again (this is fine) but suddently it wakes up again without motion and this last behavior is unpredictable. i hope it’s enough info for you but don’t hesitate to ask more if needed. thx
                                      moreover your script is i guess different from the one of this pull…
                                        bibi @bibi
                                        @DirkS and i see now after few hours, it won’t wake up anymore :(
                                          bibi @DirkS
                                          @DirkS forget my last posts… i restarted (reinstall MM) everything and i m trying to figure out how to avoid the black screen now…
                                          • C Offline
                                            chrisvanlaar
                                            This post is deleted!
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 6 / 11
