Navigation
    • Search
    MagicMirror² v2.15.0 is available! For more information about this release, check out this topic.
    Take back the control
    Troubleshooting
    • M
      mollobeck last edited by
      Hey there
      A new question for me
      My Magic Mirror is running however I would like to exit this kind of fullscreen mode and display the desktop + the file manager…
      Is there a keyboard shortcut or anything ?
      • Sean
        Sean Module Developer last edited by Sean
        Ctrl+q or Ctrl+c suddenly I’m confused but one of both will work.
        Anyway if you are using pm2 for running Magicmirror, you need to command pm2 stop mm or pm2 stop magicmirror In shell after shortcut.
        • M
          Thank you for your quick answer
          Can you please tell me if there is a hack to augment contrast and luminosity on raspian ?
          Mykle1 1 Reply Last reply Reply Quote 0
          • Mykle1
            Mykle1 Project Sponsor Module Developer @mollobeck last edited by
            @mollobeck said in Take back the control:
            I don’t think so. You will likely have to make adjustments to your monitor settings directly, using the menu of the monitor itself. Unless I’m missing something.
            • M
              mollobeck last edited by mollobeck
              Thank you
              Let me explain my situation
              I bought a iiyama ProLite 32483HS display but its brightness is very low according to me… and the final result through the mirror
              Tried to put my mirror in front of my macbook with luminosity to the top : works like a charm
              I secretly hope that I did not buy this screen for nothing…
              EDIT : my mirror has a 6mm width
              Sean Mykle1 2 Replies Last reply Reply Quote 1
              • Sean
                Sean Module Developer @mollobeck last edited by
                @mollobeck
                Well… with my experience…
                Do you really need MIRROR?
                MagicMirror is also good for “Home Dashboard” or “Information Board” without 2way mirror. (Frankly, without a mirror it could look better, I think.)
                If you cannot purchase real good mirror or good display, it could be better to use it as a smart dashboard for home instead of expending more budgets.
                • Mykle1
                  There definitely needs to be the right combination of mirror and display in order for MM to look its best. Obviously, a display with bright whites and absolute blacks is preferred. And then there’s the glass or acrylic and light transmission percentages, and as you pointed out, thickness.
                  There are several topics on the forum that address each of these concerns. Do a search and you’ll see them. If you feel the display is the problem, perhaps you can return it? Sell it? Or use it for another purpose? Of course, that means buying another, but you want to be happy with the result.
