    Npm start throwing error
    5 Posts 2 Posters 2.6k Views 2 Watching
    • N Offline
      nepsilonn
      Hi there and thank you for spending time reading this message.
      I got excited very much by this project, and i decided to make a MagicMirror on my own.
      I have followed up the whole tutorial
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)
      I ended up getting an error saying Electron did not install properly.
      I did RM RF node_modules and npm install from beginning
      Still in the end it is the same error that comes up
      /home/pi/MagicMirror/node_modules/electron/index.js:9
      throw new Error - Electron failed to install correctly, please delete node_modules/electro and try installing again.
      [0_1506123706492_npm-debug.log](Uploading 100%)
      Below here i am pasting the npm-debug.log
      Any help is appreciated. Thank you.
      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
      2 info using npm@3.10.10
      3 info using node@v6.11.3
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.1.2~prestart: magicmirror@2.1.2
      6 silly lifecycle magicmirror@2.1.2~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.1.2~start: magicmirror@2.1.2
      8 verbose lifecycle magicmirror@2.1.2~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.1.2~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      10 verbose lifecycle magicmirror@2.1.2~start: CWD: /home/pi/MagicMirror
      11 silly lifecycle magicmirror@2.1.2~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
      12 silly lifecycle magicmirror@2.1.2~start: Returned: code: 1 signal: null
      13 info lifecycle magicmirror@2.1.2~start: Failed to exec start script
      14 verbose stack Error: magicmirror@2.1.2 start: sh run-start.sh
      14 verbose stack Exit status 1
      14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
      14 verbose stack at emitTwo (events.js:106:13)
      14 verbose stack at EventEmitter.emit (events.js:191:7)
      14 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
      14 verbose stack at ChildProcess.emit (events.js:191:7)
      14 verbose stack at maybeClose (internal/child_process.js:920:16)
      14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
      15 verbose pkgid magicmirror@2.1.2
      16 verbose cwd /home/pi/MagicMirror
      17 error Linux 4.9.41-v7+
      18 error argv “/usr/bin/node” “/usr/bin/npm” “start”
      19 error node v6.11.3
      20 error npm v3.10.10
      21 error code ELIFECYCLE
      22 error magicmirror@2.1.2 start: sh run-start.sh
      22 error Exit status 1
      23 error Failed at the magicmirror@2.1.2 start script ‘sh run-start.sh’.
      23 error Make sure you have the latest version of node.js and npm installed.
      23 error If you do, this is most likely a problem with the magicmirror package,
      23 error not with npm itself.
      23 error Tell the author that this fails on your system:
      23 error sh run-start.sh
      23 error You can get information on how to open an issue for this project with:
      23 error npm bugs magicmirror
      23 error Or if that isn’t available, you can get their info via:
      23 error npm owner ls magicmirror
      23 error There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      • N Offline
        nepsilonn
        Just a small update.
        I have followed the suggestions made from Mykle1 on some posts below, but i did not get any good results of this.
        I did manual installation and i still get exactly the same error.
          Mykle1 Project Sponsor Module Developer @nepsilonn
          @nepsilonn said in Npm start throwing error:
          This is telling you to delete the Electron folder
          NOT the node_modules folder, which you deleted.
          I don’t know where you think you read that I suggested that. Certainly not in this topic.
          So, what you should have done is delete JUST the Electron folder and run npm install in the MagicMirror directory
          • N Offline
            nepsilonn @Mykle1
            https://forum.magicmirror.builders/topic/4879/npm-start/7 I read your suggestion from here.
            Not the rm rf as a suggestion from you, but rather manual installation.
            Now it works, thank you for this.
              That’s good news. Enjoy your mirror.
