    After update, Calendar shows infinite number of events.
    16 Posts 6 Posters 8.1k Views 6 Watching
    • O Offline
      orayoflighto Project Sponsor @kvicksson
      @kvicksson
      Did you put maximumEntries after each URL call like below?
      url: ‘https://google.com/public/basic.ics’,
      maximumEntries: ‘10’,
      • G Offline
        gripworks @orayoflighto
        @orayoflighto
        No I didn’t. When I set it up last year, I must have missed that. I’ll give it a try. Thank you.
        • O Offline
          You didn’t miss it. It is a change with the most recent update.
          slametpsS 1 Reply Last reply Reply Quote 0
          • slametpsS Offline
            slametps @orayoflighto
            @orayoflighto said in After update, Calendar shows infinite number of events.:
            Default value for maximumEntries is 10. How can the calendar module display infinite number of events because not setting maximumEntries option?
            regards,
            Slamet PS
            O G 2 Replies Last reply Reply Quote 0
            • O Offline
              orayoflighto Project Sponsor @slametps
              @slametps
              The maximumEntries setting now applies to each calendar rather than globally. So if you have 5 calendar URLs then you get 50 listings (if the default is set to 10). Before the change it would show the most recent 10 events from all of your calendars.
              • K Offline
                kvicksson
                Everything works after setting maximumEntries after each URL. I don’t like it though because it doesn’t show the 10 upcoming items due to where the items are in time. But guess I have to live with it :)
                  jasondreher
                  Is there any way to go back a version or install a prior version? I have the same calendar issue. The installation mentions git reset --hard, but I am not sure what that does.
                  G Mykle1M 2 Replies Last reply Reply Quote 0
                  • G Offline
                    gripworks @slametps
                    @slametps
                    It wasn’t truly infinite, I just have 8 Calendars so with 80 lines to display (the default 10/calendar) it ran off the bottom of the screen, behind the headlines and pushing the monthly calendar off the screen.
                    • G Offline
                      gripworks @jasondreher
                      @jasondreher Like kvicksson posted earlier in this thread
                      You can now setup on a per calendar basis, which I really like. I think it is a great imporvement.
                      • slametpsS Offline
                        slametps @kvicksson
                        @kvicksson said in After update, Calendar shows infinite number of events.:
                        IMHO, It will be better if there is still a global config limiting total closest event will be displayed.
                        regards,
                        Slamet PS
