    After update, Calendar shows infinite number of events.
    16 Posts 6 Posters 9.8k Views 6 Watching
    • G Offline
      gripworks @orayoflighto
      @orayoflighto
      No I didn’t. When I set it up last year, I must have missed that. I’ll give it a try. Thank you.
      • O Offline
        orayoflighto Project Sponsor
        You didn’t miss it. It is a change with the most recent update.
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS Offline
          slametps @orayoflighto
          @orayoflighto said in After update, Calendar shows infinite number of events.:
          Default value for maximumEntries is 10. How can the calendar module display infinite number of events because not setting maximumEntries option?
          regards,
          Slamet PS
          O G 2 Replies Last reply Reply Quote 0
          • O Offline
            orayoflighto Project Sponsor @slametps
            @slametps
            The maximumEntries setting now applies to each calendar rather than globally. So if you have 5 calendar URLs then you get 50 listings (if the default is set to 10). Before the change it would show the most recent 10 events from all of your calendars.
            • K Offline
              kvicksson
              Everything works after setting maximumEntries after each URL. I don’t like it though because it doesn’t show the 10 upcoming items due to where the items are in time. But guess I have to live with it :)
                jasondreher
                Is there any way to go back a version or install a prior version? I have the same calendar issue. The installation mentions git reset --hard, but I am not sure what that does.
                G Mykle1M 2 Replies Last reply Reply Quote 0
                • G Offline
                  gripworks @slametps
                  @slametps
                  It wasn’t truly infinite, I just have 8 Calendars so with 80 lines to display (the default 10/calendar) it ran off the bottom of the screen, behind the headlines and pushing the monthly calendar off the screen.
                  • G Offline
                    gripworks @jasondreher
                    @jasondreher Like kvicksson posted earlier in this thread
                    Did you put maximumEntries after each URL call like below?
                    url: ‘https://google.com/public/basic.ics’,
                    maximumEntries: ‘10’,
                    You can now setup on a per calendar basis, which I really like. I think it is a great imporvement.
                    • slametpsS Offline
                      slametps @kvicksson
                      @kvicksson said in After update, Calendar shows infinite number of events.:
                      IMHO, It will be better if there is still a global config limiting total closest event will be displayed.
                      regards,
                      Slamet PS
                        Mykle1 Project Sponsor Module Developer @jasondreher
                        @jasondreher said in After update, Calendar shows infinite number of events.:
                        https://github.com/MichMich/MagicMirror/releases
                        Move or rename your current MagicMirror folder and you won’t lose anything
                          jasondreher @Mykle1
                          @Mykle1
                          Thanks, I was looking there, but now I see the “Source code (zip)” link! I just replaced the calendar module and now it is back to the way I want it.
