    Can not start MM anymore
    3 Posts 3 Posters 1.9k Views 2 Watching
    • foxF Offline
      fox
      Hi, i have some problems - mainly after the latest update.
      I cant start MM anymore.
      The logfile (/home/pi/.npm/_logs/2017-10-14T02_58_48_833Z-debug.log)
      1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'bugs', 'magicmirror' ]
      2 info using npm@4.2.0
      3 info using node@v7.10.1
      4 silly fetchPackageMetaData magicmirror
      5 silly fetchNamedPackageData magicmirror
      6 silly mapToRegistry name magicmirror
      7 silly mapToRegistry using default registry
      8 silly mapToRegistry registry https://registry.npmjs.org/
      9 silly mapToRegistry data Result {
      9 silly mapToRegistry   raw: 'magicmirror',
      9 silly mapToRegistry   scope: null,
      9 silly mapToRegistry   escapedName: 'magicmirror',
      9 silly mapToRegistry   name: 'magicmirror',
      9 silly mapToRegistry   rawSpec: '',
      9 silly mapToRegistry   spec: 'latest',
      9 silly mapToRegistry   type: 'tag' }
      10 silly mapToRegistry uri https://registry.npmjs.org/magicmirror
      11 verbose request uri https://registry.npmjs.org/magicmirror
      12 verbose request no auth needed
      13 info attempt registry request try #1 at 04:58:46
      14 verbose request id 3fa149b5af7f1094
      15 verbose etag W/"56fbae0b-bef"
      16 verbose lastModified Wed, 30 Mar 2016 10:44:27 GMT
      17 http request GET https://registry.npmjs.org/magicmirror
      18 http 304 https://registry.npmjs.org/magicmirror
      19 verbose headers { date: 'Sat, 14 Oct 2017 02:58:46 GMT',
      19 verbose headers   via: '1.1 varnish',
      19 verbose headers   'cache-control': 'max-age=300',
      19 verbose headers   etag: 'W/"56fbae0b-bef"',
      19 verbose headers   age: '22',
      19 verbose headers   connection: 'keep-alive',
      19 verbose headers   'x-served-by': 'cache-hhn1550-HHN',
      19 verbose headers   'x-cache': 'HIT',
      19 verbose headers   'x-cache-hits': '1',
      19 verbose headers   'x-timer': 'S1507949927.624052,VS0,VE0',
      19 verbose headers   vary: 'Accept-Encoding, Accept' }
      20 silly get cb [ 304,
      20 silly get   { date: 'Sat, 14 Oct 2017 02:58:46 GMT',
      20 silly get     via: '1.1 varnish',
      20 silly get     'cache-control': 'max-age=300',
      20 silly get     etag: 'W/"56fbae0b-bef"',
      20 silly get     age: '22',
      20 silly get     connection: 'keep-alive',
      20 silly get     'x-served-by': 'cache-hhn1550-HHN',
      20 silly get     'x-cache': 'HIT',
      20 silly get     'x-cache-hits': '1',
      20 silly get     'x-timer': 'S1507949927.624052,VS0,VE0',
      20 silly get     vary: 'Accept-Encoding, Accept' } ]
      21 verbose etag https://registry.npmjs.org/magicmirror from cache
      22 verbose get saving magicmirror to /home/pi/.npm/registry.npmjs.org/magicmirror/.cache.json
      23 verbose correctMkdir /home/pi/.npm correctMkdir not in flight; initializing
      24 silly bugs url https://github.com/MichMich/MagicMirror/issues
      25 verbose stack Error: Command failed: xdg-open https://github.com/MichMich/MagicMirror/issues
      25 verbose stack /usr/bin/xdg-open: 1: eval: www-browser: not found
      25 verbose stack /usr/bin/xdg-open: 1: eval: links2: not found
      25 verbose stack /usr/bin/xdg-open: 1: eval: elinks: not found
      25 verbose stack /usr/bin/xdg-open: 1: eval: links: not found
      25 verbose stack /usr/bin/xdg-open: 1: eval: lynx: not found
      25 verbose stack /usr/bin/xdg-open: 1: eval: w3m: not found
      25 verbose stack xdg-open: no method available for opening 'https://github.com/MichMich/MagicMirror/issues'
      25 verbose stack
      25 verbose stack     at ChildProcess.exithandler (child_process.js:205:12)
      25 verbose stack     at emitTwo (events.js:106:13)
      25 verbose stack     at ChildProcess.emit (events.js:194:7)
      25 verbose stack     at maybeClose (internal/child_process.js:899:16)
      25 verbose stack     at Socket. (internal/child_process.js:342:11)
      25 verbose stack     at emitOne (events.js:96:13)
      25 verbose stack     at Socket.emit (events.js:191:7)
      25 verbose stack     at Pipe._handle.close [as _onclose] (net.js:511:12)
      26 verbose cwd /home/pi/MagicMirror
      27 error Linux 4.9.35-v7+
      28 error argv "/usr/bin/nodejs" "/usr/bin/npm" "bugs" "magicmirror"
      29 error node v7.10.1
      30 error npm  v4.2.0
      31 error code 3
      32 error Command failed: xdg-open https://github.com/MichMich/MagicMirror/issues
      32 error /usr/bin/xdg-open: 1: eval: www-browser: not found
      32 error /usr/bin/xdg-open: 1: eval: links2: not found
      32 error /usr/bin/xdg-open: 1: eval: elinks: not found
      32 error /usr/bin/xdg-open: 1: eval: links: not found
      32 error /usr/bin/xdg-open: 1: eval: lynx: not found
      32 error /usr/bin/xdg-open: 1: eval: w3m: not found
      32 error xdg-open: no method available for opening 'https://github.com/MichMich/MagicMirror/issues'
      33 error If you need help, you may report this error at:
      33 error
      34 verbose exit [ 1, true ]
      and tail of the mm-error file:
      npm ERR!     /home/pi/.npm/_logs/2017-10-14T02_58_23_366Z-debug.log
      error: object file .git/objects/54/95af1f76e98870ede078c41304a08747792caa is empty
      fatal: loose object 5495af1f76e98870ede078c41304a08747792caa (stored in .git/objects/54/95af1f76e98870ede078c41304a08747792caa) is corrupt
      fatal: The remote end hung up unexpectedly
      Sat Oct 14 2017 04:58:52 GMT+0200 (CEST) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
      npm ERR! Linux 4.9.35-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! node v7.10.1
      npm ERR! npm  v4.2.0
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.1.3 start: `sh run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     sh run-start.sh
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /home/pi/.npm/_logs/2017-10-14T02_58_52_966Z-debug.log
      Sat Oct 14 2017 04:59:23 GMT+0200 (CEST) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
      npm ERR! npm  v4.2.0
      npm ERR! errno 1
      npm ERR!
      npm ERR!     /home/pi/.npm/_logs/2017-10-14T02_59_23_738Z-debug.log
        Mykle1 Project Sponsor Module Developer @fox
        @fox said in Can not start MM anymore:
        Most likely the update and/or the new dependencies failed to completely install.
        Long shot: run npm istall in the MagicMirror directory and try to run your mirror.
        Best shot: https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
        • cowboysdudeC Offline
          cowboysdude Module Developer
          Other case is don’t install updates if you don’t need to…
