problem with module place
hello!
If got a problem.
Last night i added a Iframe on my mirror.
i linked it to my ipcamera link so i can see who’s at the front door.
now i wanna place the module to the middle. its not in de center
how can i do that? Printscreen Link
@kolk123 said in problem with module place:
how can i do that?
In your custom.css file you could try:
.iFrame { margin-left: -200px; }
Adjust accordingly
Hi Kolk,
Could you post the config.js relating to this iframe please.
I’m having difficulty getting an iframe to appear on MMM.Thanks.
Thanks for reply mykle1
if put it in to the css but didnt work. even with iframereload in the line between body
do you have more sugestions?richfreeman
i use MMM-Iframe reload with this code
module: “MMM-iFrameReload”,
position: “top_center”,
header: “”,
url: “http://xxx-xxxx/stream/video/mjpeg”,
width: “215%”,
height: “500px”,
position: “fixed”,
Oh, you said iFrame in your original post. No mention of “MMM-iFrameReload”. So, substitute that for iFrame. The entry does not go in the body of the custom.css file
@Mykle1 no sorry your totally right!!
I tried also without the body but that didn’t work.
width: “215%”,
Why are you using 215% for width? That’s a pretty big number…
@cowboysdude if I use less than shows the scroll bar.
@kolk123 try this in your custom css
body {
overflow:hidden;
}or this
::-webkit-scrollbar {
display: none;
@cowboysdude
Thanks for you response.! I can do that but if I make it smaller my camera shows not the hole screen. The resolution of the camera is high so if I make it smaller i can’t see everything. only thing I want is the screen in the middle.
