    problem with module place
    14 Posts 4 Posters 7.1k Views 3 Watching
    • K Offline
      kolk123
      hello!
      If got a problem.
      Last night i added a Iframe on my mirror.
      i linked it to my ipcamera link so i can see who’s at the front door.
      now i wanna place the module to the middle. its not in de center
      how can i do that? Printscreen Link
        Mykle1 Project Sponsor Module Developer @kolk123
        @kolk123 said in problem with module place:
        how can i do that?
        In your custom.css file you could try:
        .iFrame {
          margin-left: -200px;
        Adjust accordingly
          richfreeman
          Hi Kolk,
          Could you post the config.js relating to this iframe please.
          I’m having difficulty getting an iframe to appear on MMM.
          Thanks.
          • K Offline
            kolk123
            Thanks for reply mykle1
            if put it in to the css but didnt work. even with iframereload in the line between body
            do you have more sugestions?
            richfreeman
            i use MMM-Iframe reload with this code
            module: “MMM-iFrameReload”,
            position: “top_center”,
            header: “”,
            url: “http://xxx-xxxx/stream/video/mjpeg”,
            width: “215%”,
            height: “500px”,
            position: “fixed”,
            Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
              Oh, you said iFrame in your original post. No mention of “MMM-iFrameReload”. So, substitute that for iFrame. The entry does not go in the body of the custom.css file
              • K Offline
                kolk123 @Mykle1
                @Mykle1 no sorry your totally right!!
                I tried also without the body but that didn’t work.
                • cowboysdudeC Offline
                  cowboysdude Module Developer @kolk123
                  width: “215%”,
                  Why are you using 215% for width? That’s a pretty big number…
                  • K Offline
                    kolk123 @cowboysdude
                    @cowboysdude if I use less than shows the scroll bar.
                      @kolk123 try this in your custom css
                      body {
                      overflow:hidden;
                      or this
                      ::-webkit-scrollbar {
                      display: none;
                      • K Offline
                        @cowboysdude
                        Thanks for you response.! I can do that but if I make it smaller my camera shows not the hole screen. The resolution of the camera is high so if I make it smaller i can’t see everything. only thing I want is the screen in the middle.
                          @kolk123
                          Can you post what you’ve tried in your custom.css file so I can look at it?
                          K 2 Replies Last reply Reply Quote 0
                            Oh ok :)
                            • K Offline
                              kolk123 @Mykle1
                              @Mykle1 thank you for your response. sorry for the late reaction, my mother is in the hospital. i have done what i posted .
                              .iFrame {
                              and
                              .iFrame-reload {
                              margin-left: 200px;
                              and
                              .MMM-iFrameReload {
                              and if tryed it in side the body part
                              • K Offline
                                kolk123 @Mykle1
                                @Mykle1
                                if fixed it… i changed the 215% to 600px so it’s now 600px and 800px
                                and set the code line frome above in the custom ccs body {
                                overflow:hidden;
                                that works for now and almost in the middel thank for all for the support!!
