    problem with module place
    14 Posts 4 Posters 7.5k Views 3 Watching
      richfreeman
      Hi Kolk,
      Could you post the config.js relating to this iframe please.
      I’m having difficulty getting an iframe to appear on MMM.
      Thanks.
      • K Offline
        kolk123
        Thanks for reply mykle1
        if put it in to the css but didnt work. even with iframereload in the line between body
        do you have more sugestions?
        richfreeman
        i use MMM-Iframe reload with this code
        module: “MMM-iFrameReload”,
        position: “top_center”,
        header: “”,
        url: “http://xxx-xxxx/stream/video/mjpeg”,
        width: “215%”,
        height: “500px”,
        position: “fixed”,
        Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
          Mykle1 Project Sponsor Module Developer @kolk123
          @kolk123 said in problem with module place:
          Oh, you said iFrame in your original post. No mention of “MMM-iFrameReload”. So, substitute that for iFrame. The entry does not go in the body of the custom.css file
          • K Offline
            kolk123 @Mykle1
            @Mykle1 no sorry your totally right!!
            I tried also without the body but that didn’t work.
            • cowboysdudeC Offline
              cowboysdude Module Developer @kolk123
              width: “215%”,
              Why are you using 215% for width? That’s a pretty big number…
              • K Offline
                kolk123 @cowboysdude
                @cowboysdude if I use less than shows the scroll bar.
                  @kolk123 try this in your custom css
                  body {
                  overflow:hidden;
                  or this
                  ::-webkit-scrollbar {
                  display: none;
                  • K Offline
                    @cowboysdude
                    Thanks for you response.! I can do that but if I make it smaller my camera shows not the hole screen. The resolution of the camera is high so if I make it smaller i can’t see everything. only thing I want is the screen in the middle.
                      @kolk123
                      Can you post what you’ve tried in your custom.css file so I can look at it?
                      K 2 Replies Last reply Reply Quote 0
                        Oh ok :)
                        • K Offline
                          kolk123 @Mykle1
                          @Mykle1 thank you for your response. sorry for the late reaction, my mother is in the hospital. i have done what i posted .
                          .iFrame {
                          margin-left: -200px;
                          and
                          .iFrame-reload {
                          margin-left: 200px;
                          and
                          .MMM-iFrameReload {
                          and if tryed it in side the body part
                          • K Offline
                            kolk123 @Mykle1
                            @Mykle1
                            if fixed it… i changed the 215% to 600px so it’s now 600px and 800px
                            and set the code line frome above in the custom ccs body {
                            overflow:hidden;
                            that works for now and almost in the middel thank for all for the support!!
