    problem with module place
    14 Posts 4 Posters 7.7k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @kolk123
      @kolk123 said in problem with module place:
      how can i do that?
      In your custom.css file you could try:
      .iFrame {
        margin-left: -200px;
      Adjust accordingly
        richfreeman
        Hi Kolk,
        Could you post the config.js relating to this iframe please.
        I’m having difficulty getting an iframe to appear on MMM.
        Thanks.
        • K Offline
          kolk123
          Thanks for reply mykle1
          if put it in to the css but didnt work. even with iframereload in the line between body
          do you have more sugestions?
          richfreeman
          i use MMM-Iframe reload with this code
          module: “MMM-iFrameReload”,
          position: “top_center”,
          header: “”,
          url: “http://xxx-xxxx/stream/video/mjpeg”,
          width: “215%”,
          height: “500px”,
          position: “fixed”,
          Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
            Oh, you said iFrame in your original post. No mention of “MMM-iFrameReload”. So, substitute that for iFrame. The entry does not go in the body of the custom.css file
            • K Offline
              kolk123 @Mykle1
              @Mykle1 no sorry your totally right!!
              I tried also without the body but that didn’t work.
              • cowboysdudeC Offline
                cowboysdude Module Developer @kolk123
                width: “215%”,
                Why are you using 215% for width? That’s a pretty big number…
                • K Offline
                  kolk123 @cowboysdude
                  @cowboysdude if I use less than shows the scroll bar.
                    @kolk123 try this in your custom css
                    body {
                    overflow:hidden;
                    or this
                    ::-webkit-scrollbar {
                    display: none;
                    • K Offline
                      @cowboysdude
                      Thanks for you response.! I can do that but if I make it smaller my camera shows not the hole screen. The resolution of the camera is high so if I make it smaller i can’t see everything. only thing I want is the screen in the middle.
                        @kolk123
                        Can you post what you’ve tried in your custom.css file so I can look at it?
                        K 2 Replies Last reply Reply Quote 0
                          Oh ok :)
                          • K Offline
                            kolk123 @Mykle1
                            @Mykle1 thank you for your response. sorry for the late reaction, my mother is in the hospital. i have done what i posted .
                            .iFrame {
                            and
                            .iFrame-reload {
                            margin-left: 200px;
                            and
                            .MMM-iFrameReload {
                            and if tryed it in side the body part
                            • K Offline
                              kolk123 @Mykle1
                              @Mykle1
                              if fixed it… i changed the 215% to 600px so it’s now 600px and 800px
                              and set the code line frome above in the custom ccs body {
                              overflow:hidden;
                              that works for now and almost in the middel thank for all for the support!!
