    problem with module place
    14 Posts 4 Posters 7.8k Views 3 Watching
    • K
      kolk123
      Thanks for reply mykle1
      if put it in to the css but didnt work. even with iframereload in the line between body
      do you have more sugestions?
      richfreeman
      i use MMM-Iframe reload with this code
      module: “MMM-iFrameReload”,
      position: “top_center”,
      header: “”,
      url: “http://xxx-xxxx/stream/video/mjpeg”,
      width: “215%”,
      height: “500px”,
      position: “fixed”,
      Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @kolk123
        @kolk123 said in problem with module place:
        Oh, you said iFrame in your original post. No mention of “MMM-iFrameReload”. So, substitute that for iFrame. The entry does not go in the body of the custom.css file
        • K
          kolk123 @Mykle1
          @Mykle1 no sorry your totally right!!
          I tried also without the body but that didn’t work.
          • cowboysdudeC
            cowboysdude Module Developer @kolk123
            width: “215%”,
            Why are you using 215% for width? That’s a pretty big number…
            • K
              kolk123 @cowboysdude
              @cowboysdude if I use less than shows the scroll bar.
              • cowboysdudeC
                @kolk123 try this in your custom css
                body {
                overflow:hidden;
                or this
                ::-webkit-scrollbar {
                display: none;
                • K
                  @cowboysdude
                  Thanks for you response.! I can do that but if I make it smaller my camera shows not the hole screen. The resolution of the camera is high so if I make it smaller i can’t see everything. only thing I want is the screen in the middle.
                  • Mykle1M
                    @kolk123
                    Can you post what you’ve tried in your custom.css file so I can look at it?
                    K 2 Replies Last reply Reply Quote 0
                    • cowboysdudeC
                      Oh ok :)
                      • K
                        kolk123 @Mykle1
                        @Mykle1 thank you for your response. sorry for the late reaction, my mother is in the hospital. i have done what i posted .
                        .iFrame {
                        margin-left: -200px;
                        and
                        .iFrame-reload {
                        margin-left: 200px;
                        and
                        .MMM-iFrameReload {
                        and if tryed it in side the body part
                        • K
                          kolk123 @Mykle1
                          @Mykle1
                          if fixed it… i changed the 215% to 600px so it’s now 600px and 800px
                          and set the code line frome above in the custom ccs body {
                          overflow:hidden;
                          that works for now and almost in the middel thank for all for the support!!
