    Which Pi version is best?
    14 Posts 6 Posters 12.4k Views 5 Watching
    • A
      austenzombie7
      I’ve been searching the forum and I’m curious, what pi version do people have the most luck with? I see some incompatibility issues with Stretch? So is Jessie the best route to take?
      I was going to use the auto installer command line and am trying to avoid some heartache out of the box (like when I had to kill my Stretch pi after trying to install RetroPie manually and the last line of code came back with Retro & I hate each other).
      • Nystro0mN
        Nystro0m
        Any pi except Raspberry Pi Zero.
        Jessie is the way to go for autoinstaller.
        Raspberry pi 3 is the fastest atm (and i would by that decider the best).
        However, you will have a rough time in front of you if you see installing Magic Mirror by the manual process is a heartache.
        • SexyTroggS
          SexyTrogg
          I agree with the PI 3. I’ve built a mirror using the PI 3 and the new(er) Pi 0 and it was night and day easier with the PI 3. It’ll of course cost you more up front and its a little bigger but its more powerful and easier to use ‘out of the box’
          • A
            austenzombie7
            Thank you! I have a Pi2 and Pi3 but was trying to decide Stretch vs Jessie. I could have installed manually but am pretty new to Pi so didn’t want to muck it. Like I said, started manually installing RetroPie manually only to get near the end and find Stretch was not compatible. Three days of research and troubleshooting (as am noob) to get me all sorted.
            Am booting Jessie on Pi3 now, thanks again!
            • SexyTroggS
              SexyTrogg
              @austenzombie7 I’ve set up a RetroPi but only using Jessie so I couldn’t help with Stretch. Maybe give RecalBox a look too as it is very very similar to RetroPi
              Mykle1M 1 Reply Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @SexyTrogg
                @SexyTrogg
                Editorial
                If your heart is set on the Pi then the Pi3 is your best option, with Jessie. More importantly, IMHO, if you MUST use Stretch, DO NOT run rpi-update. You’ve been warned.
                A 1 Reply Last reply
                • J
                  juvesito
                  Hi guys, I’m trying to test with MagicMirror and I bought Raspberry pi 3, but I have question 8)
                  What is the best version of linux is better for install the MagicMirror ?
                  RASPBIAN STRETCH WITH DESKTOP or RASPBIAN STRETCH LITE ?
                  Thanks in advance !
                  Nystro0mN A cowboysdudeC 3 Replies Last reply
                  • Nystro0mN
                    Nystro0m @juvesito
                    @juvesito Go with Jessie.
                    J 1 Reply Last reply
                    Reply Quote 1
                    • J
                      juvesito @Nystro0m
                      @Nystro0m I undertand that for to install the MagicMirror is better the desktop version no? Thanks for your fast answer 8)
                      Nystro0mN 1 Reply Last reply
                      • Nystro0mN
                        Nystro0m @juvesito
                        @juvesito If you are comfortable to go without destkop i would go that way.
                        Otherwise, both works.
                        Reply Quote 1
                        • A
                          austenzombie7 @juvesito
                          @juvesito USE JESSIE! I found the best way to do this is to go here and I selected the one from 03/03/2017 and downloaded the zip file then unzipped it and used Win32 or Etcher to write the image to the micro SD. You’ll still have to run the
                          sudo apt-get update
                          sudo apt-get upgrade
                          commands but I’m still finding my way in the pi world, so I’m sure there’s an easier way. Anyways, no issues this way so far on Pi3 :)
                          • A
                            austenzombie7 @Mykle1
                            @Mykle1
                            @Mykle1 said in Which Pi version is best?:
                            @SexyTrogg
                            Editorial
                            I stand warned and used Jessie! Thanks!!!
                            Reply Quote 1
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @austenzombie7
                              @austenzombie7 said in Which Pi version is best?:
                              Very good, Sir. Enjoy your mirror!
                              • cowboysdudeC
                                cowboysdude Module Developer @juvesito
                                @juvesito said in Which Pi version is best?:
                                Thanks in advance !
                                You didn’t read the post right above yours? LOL
                                SO yeah not a good idea… use Jessie
                                Reply Quote 1
