    Third Party Modules Don't Work Please Help
    21 Posts 5 Posters 11.1k Views 4 Watching
    • Z Offline
      zzaidi148
      Hello all,
      I’m a total noob to coding and magicmirror. I’ve got my mm working perfectly with the default modules. but for some reason when I add 3rd party modules, it all fails and says your config doesnt work. I download the module into MagicMirror/modules and not in default. I also added the config to config.js in every place imaginable and never got it to work. Please, if you can help, speel it out to me because I’m a total noob! My config is below. I tried it with many modules besides this google maps one that is at the bottom. The same result occured.
      //var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check-o ",
      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "4684888",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "private"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "private"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      var config = {
                  module: 'MMM-GoogleMapsTraffic',
                      key: 'YOUR_KEY',
                      lat: 37.8262306,
                      lng: -122.2920096,
                      height: '300px',
                      width: '300px'
      • cowboysdudeC Offline
        cowboysdude Module Developer
        @zzaidi148 said in Third Party Modules Don’t Work Please Help:
        //var config
        should be
        var config take the // away
          https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
            Rule of thumb for new guys/gals…
            Add one module at a time… if your config works then back it up before adding something else that way you have a working config… always :)
            Z 1 Reply Last reply Reply Quote 3
              Bob
              remove the second instance of
              var config = (
              module : [
              at the bottom of the file
              • Z Offline
                zzaidi148 @cowboysdude
                @cowboysdude I tried with only one module and it failed
                cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 0
                  cowboysdude Module Developer @zzaidi148
                  @zzaidi148 It’s okay it’s how we learn :) We’ve all been there… if you try to get one module working and it doesn’t then post what you’ve done so we can help you…
                  We don’t mind … like I said we ALL had to learn and there is no such thing as a stupid question ever. I personally don’t care if you have to ask the same question 1000 times… I or someone else will answer you.
                  My education is in Education :) Just remember… whatever question you ask someone else may benefit from it too!
                  Z 2 Replies Last reply Reply Quote 0
                    Mykle1 Project Sponsor Module Developer @zzaidi148
                    Your default config works, yes?
                    Z 1 Reply Last reply Reply Quote 0
                      Bob
                      Ho hum, I got bored, so…
                      @zzaidi148 here you go, below is your working code.
                      As was said above, you needed to remove the // from var config, and the extra config section at the end. I also tidied up the code (putting spaces between modules to make them easier to read), and added some extra commas (because I tend to anyway) . You just need to replace the API keys with the correct ones and the code below will work.
                      var config = {
                      	port: 8080,
                      	language: "en",
                      	timeFormat: 12,
                      	units: "imperial",
                      			module: "alert",
                      			position: "top_bar",
                      			module: "clock",
                      						symbol: "calendar-check-o",
                      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                      			position: "lower_third",
                      				appid: "private",
                      				appid: "private",
                      			module: "newsfeed",
                      				feeds: [
                                      key: 'YOUR_KEY',
                                      lat: 37.8262306,
                                      lng: -122.2920096,
                                      height: '300px',
                                      width: '300px',
                      • Z Offline
                        zzaidi148 @Mykle1
                        @Mykle1 yes
                        • 1 / 3
