    Use PI camera instead of USB
    8 Posts 2 Posters 5.7k Views 2 Watching
    • J
      Johans
      Re: Camera module
      can I also use the rasp-Pi camera instead of a USB cam?
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Johans
        @Johans said in Use PI camera instead of USB:
        Well, what does it say in the ReadME?
        I think there is a module that supports the Pi Cam
        • J
          Johans @Mykle1
          @Mykle1
          indeed the “read me” file says USB webcam.
          any idea of module name for MM that does the same but with a PI cam ?
          • Mykle1M
            I did look here for you but I don’t see the module for the PiCam listed. I’m sure I’ve read about it on the forum. I don’t know that it does the same thing as the module you were asking about.
            J 2 Replies Last reply Reply Quote 0
            • J
              Johans @Mykle1
              @Mykle1
              I also looked there before and couldn’t find it.
              i’ll keep searching …
              thx
              • J
                Johans @Mykle1
                @Mykle1
                found something here, but unfortunately no one mentioned the module used.
                https://forum.magicmirror.builders/topic/2143/using-the-raspberry-pi-camera-to-see-through-the-mirror
                • Mykle1M
                  @Johans
                  Yes, I see.
                  This one is for facial recognition
                  https://github.com/paviro/MMM-Facial-Recognition
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @Mykle1
                    @Johans
                    Hopefully someone will help you out in the other topic. Good luck, mate.
                    Cheers
