    MM not starting after install
    9 Posts 3 Posters 6.7k Views 2 Watching
      AnduriI
      Hey there,
      I have a freshly installed RPi3 with jessie-lite, with sudo apt-get update && sudo apt-get upgrade done. I installed MM with bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)" (without any errors) and tried to start with DISPLAY=:0 nohup npm start &
      The error in ~/MagicMirror/nohup.out shows the following:
      > magicmirror@2.1.3 start /home/pi/MagicMirror
      > sh run-start.sh
      /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-x11-2.0.so.0: cannot open shared object file: No such file or directory
      npm ERR! Linux 4.9.35-v7+
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
      npm ERR! node v6.11.5
      npm ERR! npm  v3.10.10
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.1.3 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     sh run-start.sh
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm-debug.log:
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@3.10.10
      3 info using node@v6.11.5
      5 info lifecycle magicmirror@2.1.3~prestart: magicmirror@2.1.3
      6 silly lifecycle magicmirror@2.1.3~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.1.3~start: magicmirror@2.1.3
      8 verbose lifecycle magicmirror@2.1.3~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.1.3~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bi$
      10 verbose lifecycle magicmirror@2.1.3~start: CWD: /home/pi/MagicMirror
      11 silly lifecycle magicmirror@2.1.3~start: Args: [ '-c', 'sh run-start.sh' ]
      12 info lifecycle magicmirror@2.1.3~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.1.3 start: `sh run-start.sh`
      13 verbose stack spawn ENOENT
      13 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)
      13 verbose stack     at emitTwo (events.js:106:13)
      13 verbose stack     at ChildProcess.emit (events.js:191:7)
      13 verbose stack     at maybeClose (internal/child_process.js:920:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
      14 verbose pkgid magicmirror@2.1.3
      15 verbose cwd /home/pi/MagicMirror
      16 error Linux 4.9.35-v7+
      17 error argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 error node v6.11.5
      19 error npm  v3.10.10
      20 error file sh
      21 error code ELIFECYCLE
      22 error errno ENOENT
      23 error syscall spawn
      24 error magicmirror@2.1.3 start: `sh run-start.sh`
      24 error spawn ENOENT
      25 error Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
      25 error Make sure you have the latest version of node.js and npm installed.
      25 error If you do, this is most likely a problem with the magicmirror package,
      25 error not with npm itself.
      25 error Tell the author that this fails on your system:
      25 error     sh run-start.sh
      25 error You can get information on how to open an issue for this project with:
      25 error     npm bugs magicmirror
      25 error Or if that isn't available, you can get their info via:
      25 error     npm owner ls magicmirror
      25 error There is likely additional logging output above.
      26 verbose exit [ 1, true ]
      As the error ist talking about x11 I also tried to manually install x11vnc (see here: https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi), but that din’t change anything.
      Regards,
      AnduriI
        Mykle1 Project Sponsor Module Developer @AnduriI
        @AnduriI said in MM not starting after install:
        I believe that your dependencies did not fully install for electron, based on the above error message. Try this:
        Move or rename or delete the electron folder from the /home/pi/MagicMirror/node_modules/ directory.
        Then run npm install in the /home/pi/MagicMirror/ directory.
        Then run npm start in the /home/pi/MagicMirror/ directory
          AnduriI
          well that didn’t worked…
          I installed libgtk manually, now a new error: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
          Again, installed that manually and found libnss3.soto be missing… let’s follow this route and see where it leads me…
            AnduriI
            well it looks like this was the last one missing, but still it does not work.
            npm-debug.log:
            9 verbose lifecycle magicmirror@2.1.3~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/l$
            12 silly lifecycle magicmirror@2.1.3~start: Returned: code: 1  signal: null
            13 info lifecycle magicmirror@2.1.3~start: Failed to exec start script
            14 verbose stack Error: magicmirror@2.1.3 start: `sh run-start.sh`
            14 verbose stack Exit status 1
            14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
            14 verbose stack     at emitTwo (events.js:106:13)
            14 verbose stack     at EventEmitter.emit (events.js:191:7)
            14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
            14 verbose stack     at ChildProcess.emit (events.js:191:7)
            14 verbose stack     at maybeClose (internal/child_process.js:920:16)
            14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
            15 verbose pkgid magicmirror@2.1.3
            16 verbose cwd /home/pi/MagicMirror
            17 error Linux 4.9.35-v7+
            18 error argv "/usr/bin/node" "/usr/bin/npm" "start"
            19 error node v6.11.5
            20 error npm  v3.10.10
            22 error magicmirror@2.1.3 start: `sh run-start.sh`
            22 error Exit status 1
            23 error Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
            23 error Make sure you have the latest version of node.js and npm installed.
            23 error If you do, this is most likely a problem with the magicmirror package,
            23 error not with npm itself.
            23 error Tell the author that this fails on your system:
            23 error     sh run-start.sh
            23 error You can get information on how to open an issue for this project with:
            23 error     npm bugs magicmirror
            23 error Or if that isn't available, you can get their info via:
            23 error     npm owner ls magicmirror
            23 error There is likely additional logging output above.
            24 verbose exit [ 1, true ]
            I don’t see any message saying why it failed…
              I’ve never used Jessie lite or run node server only so I am a bit at a loss here. Often, troubleshooting can take longer than re-installation. In which case, I usually recommend a manual install. That has always worked for me, although I only use the full version of Jessie
                AnduriI
                yeah I know what you mean… I will try a re-install with full jessie and manual install. I will report back after that… thanks a lot.
                  bhepler Module Developer @AnduriI
                  @AnduriI If you’re worried about overhead and other useless applications on your Pi, the Complete Setup Tutorial has a useful command to uninstall a lot of the stuff you won’t use in a normal Raspbian image. It will pull out the Wolfram engine, LibreOffice, Minecraft, etc.
                    AnduriI
                    @bhepler well me using raspbian lite is just a habit and was not to decrease load. I have 3+ RPis all running headless with raspbian lite.
                    But doing a re-install was a good idea. Have a full jessie installed now and setup of MM went fine the manuall way. Also it seems to be starting, but I can’t reach it from my pc. Monitor for MM has not yet arrived.
                    pi@Spieglein:~/MagicMirror $  DISPLAY=:0 nohup npm start &
                    [1] 3579
                    pi@Spieglein:~/MagicMirror $ nohup: ignoriere Eingabe und hänge Ausgabe an „nohup.out“ an
                    nohup.out:
                    > sh run-start.sh
                    Starting MagicMirror: v2.1.3
                    Loading config ...
                    Loading module helpers ...
                    All module helpers loaded.
                    You're using a full whitelist configuration to allow for all IPs
                    Server started ...
                    Starting module: newsfeed
                    Launching application.
                    Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300$
                    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                    config.js:
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                            port: 8080,
                            ipWhitelist: [], // Set [] to allow all IP addresses
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::f$
        // or IPv4 range of 192.168.3.0 --> 192.168.3.15$
                            language: "de",
                            timeFormat: 24,
                            units: "metric",
                    [didn't changed anything below here yet]
                    But there is no page available at Spieglein:8080 or [IP]:8080. Did I miss a point in the config?
                      AnduriI
                      adding an address: "0.0.0.0",did it, I can see the black page of MM in my browser… thanks a lot for your help. Now I’m even more waiting for my mirror and screen to arrive…
