    I need help!!!!
    26 Posts 4 Posters 16.8k Views 4 Watching
      danwitz65 @tbbear
      @tbbear said in I need help!!!!:
      @danwitz65 ok, lets fix it step by step:
      1. Rotate the screen (works for all normal displays, not for pi special and touchscreens)
      Open a terminal and login to your pi
      sudo nano /boot/config.txt
      move all the way down to the end of the file
      add the line: display_rotate=3
      Press ctrl + o to save and ctrl + x to exit the file
      Now do a reboot and you should have a screen tilted by the number of your desire:
      0 = 0 degrees (the default value)
      1 = 90 degrees
      2 = 180 degrees
      3 = 270 degrees
      That’s it! Quick and easy.
      Oh hell thats gotta be my problem there i didnt realize save was ctrl+o i was kust doing x i think. Ill report back once i try it thanks a ton!
      1 Reply Last reply Reply Quote -1
        danwitz65
        Ok sweet got it! Thank you!!
          danwitz65
          Oh my god worse problems now…
          Id tryed editing my wifi auto turn off thing and followed a thing on line that said to delete the contents and type in what they had and now i dont have any internet at all and dont have my original file… do you have the original networks interfaces file…
            danwitz65
            Never mind fixed it.
            Anyways where im at now is trying to get it to auto start when the the powers on ive got pm2 ive tryed making the mm.sh file but that isnt working can i get a hand from the beginning of that process getting it to auto start.
              Mykle1 Project Sponsor Module Developer @danwitz65
              @danwitz65
              https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                danwitz65
                I dont understand this command and section
                Whats a shell script
                cd ~
                nano mm.sh
                Where do you put it how do you get it to work
                And then id like to set my weather in adams wisconsin how do i do that i got my key or whatever and put it in so it shows up on the mirror but it says new york and i tryed just typing in adams and madison wi and it wouldnt switch over
                Again thank you for all your help
                  @danwitz65 said in I need help!!!!:
                  I think the default locationID: "5128581", is for New York. You would have to change that to locationID: "5243553", in your config entry. The readMe file for weather tells you to get it at http://openweathermap.org/help/city_list.txt. I looked it up for you, based on Adams, WI.
                  Otherwise, you could put Adams,WI in location (no space) and locationID: "5243553",
                    danwitz65
                    Oh my god thank you so much!
                    Whil i got you hear can you help me through getting magic mirror to boot up automatically. Ive tryed and made the shell script i can run all the commands to get it to run then i try pm2 save and the sudo reboot.
                    The mirror loading screen shows up then goes blank and boots back up to raspbian desktop… its driving me nuts
                      @danwitz65
                      Perhaps you’re not saving the PM2 state correctly. I would only tell you exactly what is written here.
                        danwitz65
                        Yeah idk i follow it step by step but when it loads up it just shows four raspberrys then magic mirror2 “booting up” then the raspbian home highway picture desktop… idk what im doing wrong
                        • 3 / 3
