    I need help!!!!
    26 Posts 4 Posters 18.3k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @danwitz65
      @danwitz65
      Perhaps you’re not saving the PM2 state correctly. I would only tell you exactly what is written here.
      https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
        danwitz65
        Yeah idk i follow it step by step but when it loads up it just shows four raspberrys then magic mirror2 “booting up” then the raspbian home highway picture desktop… idk what im doing wrong
          @danwitz65
          Are you waiting when that happens? There is a delay between the time you see the desktop and when PM2 launches the mirror. How long are you waiting?
            danwitz65
            Idk it never has launched after a reboot ive had to do it manually in terminal everything’s me so far
            Also when you type
            chmod +x mm.sh
            From that guide is terminal supposed to do something?
              @danwitz65
              It will make the shell script is executable. I don’t recall if there is any output to confirm. It may simply go back to your directory
                danwitz65
                Yeah it doesnt confirm back with anything just opens a line for another command.
                Also just tryed rebooting and waiting its been 7 mins now and magic mirror hasnt popped up
                  @danwitz65
                  Well, it shouldn’t take THAT long. If you run pm2 start mm in the terminal, does it launch the mirror?
                    danwitz65
                    Yes it does
                    Just did it as well to be sure
                      @danwitz65
                      All I can do is suggest you go through the entire process again. Create the script. Make sure it’s not inside your MagicMirror folder, etc . . and follow the instructions precisely. If there is something else going on there then perhaps a fresh install is in order, but that is completely up to you
                        danwitz65
                        Well thanks a ton for the help im not gonna reinstall the whole thing that would be crazy ill just have to deal with it i guess…
                          austin
                          Did you run this command?
                          pm2 startup
                          This will give you a command to run to setup pm2 to start at boot.
                            Mykle1 Project Sponsor Module Developer @austin
                            @austin
                            @danwitz65 stated
                              austin
                              @Mykle
                              The first time I ran this command I thought it was done. I did not realize that it returns a command to run.
                              So since I made this mistake I figured I would ask if the command was run and to check for it to return a different command to run.
                                @austin
                                “pm2 startup”
                                “PM2 will now show you a command you need to execute.”
