    I need help!!!!
    26 Posts 4 Posters 19.0k Views 4 Watching
      danwitz65
      Idk it never has launched after a reboot ive had to do it manually in terminal everything’s me so far
      Also when you type
      chmod +x mm.sh
      From that guide is terminal supposed to do something?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @danwitz65
        @danwitz65
        It will make the shell script is executable. I don’t recall if there is any output to confirm. It may simply go back to your directory
          danwitz65
          Yeah it doesnt confirm back with anything just opens a line for another command.
          Also just tryed rebooting and waiting its been 7 mins now and magic mirror hasnt popped up
          • Mykle1M
            @danwitz65
            Well, it shouldn’t take THAT long. If you run pm2 start mm in the terminal, does it launch the mirror?
              danwitz65
              Yes it does
              Just did it as well to be sure
              • Mykle1M
                @danwitz65
                All I can do is suggest you go through the entire process again. Create the script. Make sure it’s not inside your MagicMirror folder, etc . . and follow the instructions precisely. If there is something else going on there then perhaps a fresh install is in order, but that is completely up to you
                  danwitz65
                  Well thanks a ton for the help im not gonna reinstall the whole thing that would be crazy ill just have to deal with it i guess…
                  • A
                    austin
                    Did you run this command?
                    pm2 startup
                    This will give you a command to run to setup pm2 to start at boot.
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @austin
                      @austin
                      @danwitz65 stated
                      Yeah idk i follow it step by step
                      • A
                        austin
                        @Mykle
                        The first time I ran this command I thought it was done. I did not realize that it returns a command to run.
                        So since I made this mistake I figured I would ask if the command was run and to check for it to return a different command to run.
                        • Mykle1M
                          @austin
                          “pm2 startup”
                          “PM2 will now show you a command you need to execute.”
