    I need help!!!!
    26 Posts 4 Posters 18.5k Views 4 Watching
      danwitz65
      Oh my god worse problems now…
      Id tryed editing my wifi auto turn off thing and followed a thing on line that said to delete the contents and type in what they had and now i dont have any internet at all and dont have my original file… do you have the original networks interfaces file…
        danwitz65
        Never mind fixed it.
        Anyways where im at now is trying to get it to auto start when the the powers on ive got pm2 ive tryed making the mm.sh file but that isnt working can i get a hand from the beginning of that process getting it to auto start.
          Mykle1 Project Sponsor Module Developer @danwitz65
          @danwitz65
          https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
            danwitz65
            I dont understand this command and section
            Whats a shell script
            cd ~
            nano mm.sh
            Where do you put it how do you get it to work
            And then id like to set my weather in adams wisconsin how do i do that i got my key or whatever and put it in so it shows up on the mirror but it says new york and i tryed just typing in adams and madison wi and it wouldnt switch over
            Again thank you for all your help
              @danwitz65 said in I need help!!!!:
              I think the default locationID: "5128581", is for New York. You would have to change that to locationID: "5243553", in your config entry. The readMe file for weather tells you to get it at http://openweathermap.org/help/city_list.txt. I looked it up for you, based on Adams, WI.
              Otherwise, you could put Adams,WI in location (no space) and locationID: "5243553",
                danwitz65
                Oh my god thank you so much!
                Whil i got you hear can you help me through getting magic mirror to boot up automatically. Ive tryed and made the shell script i can run all the commands to get it to run then i try pm2 save and the sudo reboot.
                The mirror loading screen shows up then goes blank and boots back up to raspbian desktop… its driving me nuts
                  @danwitz65
                  Perhaps you’re not saving the PM2 state correctly. I would only tell you exactly what is written here.
                    danwitz65
                    Yeah idk i follow it step by step but when it loads up it just shows four raspberrys then magic mirror2 “booting up” then the raspbian home highway picture desktop… idk what im doing wrong
                      @danwitz65
                      Are you waiting when that happens? There is a delay between the time you see the desktop and when PM2 launches the mirror. How long are you waiting?
                        danwitz65
                        Idk it never has launched after a reboot ive had to do it manually in terminal everything’s me so far
                        Also when you type
                        chmod +x mm.sh
                        From that guide is terminal supposed to do something?
                          @danwitz65
                          It will make the shell script is executable. I don’t recall if there is any output to confirm. It may simply go back to your directory
                            danwitz65
                            Yeah it doesnt confirm back with anything just opens a line for another command.
                            Also just tryed rebooting and waiting its been 7 mins now and magic mirror hasnt popped up
                              @danwitz65
                              Well, it shouldn’t take THAT long. If you run pm2 start mm in the terminal, does it launch the mirror?
                                danwitz65
                                Yes it does
                                Just did it as well to be sure
                                  @danwitz65
                                  All I can do is suggest you go through the entire process again. Create the script. Make sure it’s not inside your MagicMirror folder, etc . . and follow the instructions precisely. If there is something else going on there then perhaps a fresh install is in order, but that is completely up to you
                                    danwitz65
                                    Well thanks a ton for the help im not gonna reinstall the whole thing that would be crazy ill just have to deal with it i guess…
                                      austin
                                      Did you run this command?
                                      pm2 startup
                                      This will give you a command to run to setup pm2 to start at boot.
                                        Mykle1 Project Sponsor Module Developer @austin
                                        @austin
                                        @danwitz65 stated
                                          austin
                                          @Mykle
                                          The first time I ran this command I thought it was done. I did not realize that it returns a command to run.
                                          So since I made this mistake I figured I would ask if the command was run and to check for it to return a different command to run.
                                            @austin
                                            “pm2 startup”
                                            “PM2 will now show you a command you need to execute.”
