    I need help!!!!
    26 Posts 4 Posters 19.0k Views 4 Watching
      danwitz65 @tbbear
      @tbbear said in I need help!!!!:
      @danwitz65 ok, lets fix it step by step:
      1. Rotate the screen (works for all normal displays, not for pi special and touchscreens)
      Open a terminal and login to your pi
      sudo nano /boot/config.txt
      move all the way down to the end of the file
      add the line: display_rotate=3
      Press ctrl + o to save and ctrl + x to exit the file
      Now do a reboot and you should have a screen tilted by the number of your desire:
      0 = 0 degrees (the default value)
      1 = 90 degrees
      2 = 180 degrees
      3 = 270 degrees
      That’s it! Quick and easy.
      Oh hell thats gotta be my problem there i didnt realize save was ctrl+o i was kust doing x i think. Ill report back once i try it thanks a ton!
      Reply Quote -1
        danwitz65
        Ok sweet got it! Thank you!!
          danwitz65
          Oh my god worse problems now…
          Id tryed editing my wifi auto turn off thing and followed a thing on line that said to delete the contents and type in what they had and now i dont have any internet at all and dont have my original file… do you have the original networks interfaces file…
            danwitz65
            Never mind fixed it.
            Anyways where im at now is trying to get it to auto start when the the powers on ive got pm2 ive tryed making the mm.sh file but that isnt working can i get a hand from the beginning of that process getting it to auto start.
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @danwitz65
              @danwitz65
              https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                danwitz65
                I dont understand this command and section
                Whats a shell script
                cd ~
                nano mm.sh
                Where do you put it how do you get it to work
                And then id like to set my weather in adams wisconsin how do i do that i got my key or whatever and put it in so it shows up on the mirror but it says new york and i tryed just typing in adams and madison wi and it wouldnt switch over
                Again thank you for all your help
                • Mykle1M
                  @danwitz65 said in I need help!!!!:
                  I think the default locationID: "5128581", is for New York. You would have to change that to locationID: "5243553", in your config entry. The readMe file for weather tells you to get it at http://openweathermap.org/help/city_list.txt. I looked it up for you, based on Adams, WI.
                  Otherwise, you could put Adams,WI in location (no space) and locationID: "5243553",
                    danwitz65
                    Oh my god thank you so much!
                    Whil i got you hear can you help me through getting magic mirror to boot up automatically. Ive tryed and made the shell script i can run all the commands to get it to run then i try pm2 save and the sudo reboot.
                    The mirror loading screen shows up then goes blank and boots back up to raspbian desktop… its driving me nuts
                    • Mykle1M
                      @danwitz65
                      Perhaps you’re not saving the PM2 state correctly. I would only tell you exactly what is written here.
                        danwitz65
                        Yeah idk i follow it step by step but when it loads up it just shows four raspberrys then magic mirror2 “booting up” then the raspbian home highway picture desktop… idk what im doing wrong
                        • Mykle1M
                          @danwitz65
                          Are you waiting when that happens? There is a delay between the time you see the desktop and when PM2 launches the mirror. How long are you waiting?
                            danwitz65
                            Idk it never has launched after a reboot ive had to do it manually in terminal everything’s me so far
                            Also when you type
                            chmod +x mm.sh
                            From that guide is terminal supposed to do something?
                            • Mykle1M
                              @danwitz65
                              It will make the shell script is executable. I don’t recall if there is any output to confirm. It may simply go back to your directory
                                danwitz65
                                Yeah it doesnt confirm back with anything just opens a line for another command.
                                Also just tryed rebooting and waiting its been 7 mins now and magic mirror hasnt popped up
                                • Mykle1M
                                  @danwitz65
                                  Well, it shouldn’t take THAT long. If you run pm2 start mm in the terminal, does it launch the mirror?
                                    danwitz65
                                    Yes it does
                                    Just did it as well to be sure
                                    • Mykle1M
                                      @danwitz65
                                      All I can do is suggest you go through the entire process again. Create the script. Make sure it’s not inside your MagicMirror folder, etc . . and follow the instructions precisely. If there is something else going on there then perhaps a fresh install is in order, but that is completely up to you
                                        danwitz65
                                        Well thanks a ton for the help im not gonna reinstall the whole thing that would be crazy ill just have to deal with it i guess…
                                        • A
                                          austin
                                          Did you run this command?
                                          pm2 startup
                                          This will give you a command to run to setup pm2 to start at boot.
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @austin
                                            @austin
                                            @danwitz65 stated
