    Wood type for mirror frame
    4 Posts 4 Posters 3.8k Views 2 Watching
    • T Offline
      termeric
      What type of wood did you use for your frame? i’m not sure what thickness i need to make something that i sturdy enough to hold everything together.
      • brobergB Offline
        broberg Project Sponsor
        It mostly depends on your design and size of mirror. A sketch or dimensions would be useful.
        But as a general guide is if in doubt go bigger/thicker.
          Mykle1 Project Sponsor Module Developer @termeric
          @termeric
          Look at some of the builds that have been documented already. You actually see the wood being used.
          2 examples:
          https://forum.magicmirror.builders/topic/1678/1-old-noob-1-rpi-i-can-t-believe-i-did-it-revisited
          https://forum.magicmirror.builders/topic/4930/vanity-mirror-thy-name-is-woman-using-laptop
          • cowboysdudeC Offline
            cowboysdude Module Developer
            Yes you can use ANY material that you can make work. I would have preferred steel or alum but I have NO clue how to weld and paying someone would be VERY expensive…sooooooooooo I used the material I work with almost everyday…Wood.
            It’s inexpensive [depending on what you use] … I used mahogany alot… I have 3 built and they all have that in them…plus pine.
