    PIR sensor behind glass?
    65 Posts 16 Posters 102.6k Views 19 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @Nususu
      @Nususu I would go online and lookup ‘wiring pir sensor raspberry pi’ there are TONS of things out there. Your issue could be one of any or a combination of things… I did that using a PIR sensor so I have no idea how it would act with microwave sensors… good I’m hoping because I want to get some… BUT let me know if you need anymore help, not that I helped you now but I will do what I can!
        cowboysdude Module Developer @rvdgeer
        @rvdgeer and @Nususu
        Try here!
        https://www.pubnub.com/blog/2015-06-16-building-a-raspberry-pi-motion-sensor-with-realtime-alerts/
        • N Offline
          Nususu @cowboysdude
          @cowboysdude thanks, I’ll check that out and let you know how it goes!
          • N Offline
            Nususu @cowboysdude
            @cowboysdude I got it working using this code:
            https://github.com/paviro/MMM-PIR-Sensor
            With this code, I’ve got a problem where the screen only stays on for about 1 second after motion detection. Now I need to modify the code somehow to allow me to tell the mirror to stay on for a set amount of time after detecting motion, i.e. only go dark once no motion has been detected for x seconds. Problem is I don’t know where to start with that. Will let you know if I figure anything out. Any ideas?
            cowboysdudeC 1 Reply Last reply Reply Quote 1
              @Nususu try adding the powerSaving to your config…
                      module: 'MMM-PIR-Sensor',
                          powerSaving: false
              See what that does :) PLUS there’s also an adjustment on your PIR sensor itself… which one and I don’t know … do a google search for adjustments :)
                Aly
                @Nususu - same here
                Perhaps, with a resistor?
                • N Offline
                  Nususu @Aly
                  @Aly I found documentation for the sensor that a resistor would indeed solve the issue here. I can set the delay up to 200 seconds with a 250k resistor, so I ordered one and will report back how it went.
                    Aly
                    @Nususu - great !!
                    Can you post the doc. ?
                    • N Offline
                      Nususu @Aly
                      @Aly I misspoke, shouldn’t have called it documentation. Rather, it was this picture:alt text
                      Which appears to be a translation from the Chinese original picture.
                        Aly @Nususu
                        @Nususu
                        so if we remove the R6 resistor the delay would be 30s ?
                        • 6
                        • 7
                        • 6 / 7
