    PIR sensor behind glass?
    65 Posts 16 Posters 115.5k Views 19 Watching
      amcolash
      I used some cardboard and then made a little housing for my PIR under the bottom of the mirror. It is a little ugly, but hey this whole project for me was to make something cool (not necessarily beautiful)!
      I did a few layers of cardboard between the sensor and the front to limit the viewing angles and for my needs it is perfect :)
      • C Offline
        Cato Module Developer @dmcinnes
        @dmcinnes Would you mind share some code? :)
        D cowboysdudeC 2 Replies Last reply Reply Quote 0
          dmcinnes Module Developer @Cato
          @Cato just the regular PIR sensor mirror code works fine! The data pin triggers in the same way as a PIR sensor.
          • cowboysdudeC Offline
            cowboysdude Module Developer @Cato
            @Cato said in PIR sensor behind glass?:
            https://github.com/cowboysdude/Pir-Sensor
            N 1 Reply Last reply Reply Quote 1
            • ? Offline
              A Former User
              hmm… some questions if you would not mind.
              Ive just ordered 2 sensors .
              I need to know what plugs in to what to feed in to the chips (im guessing the sensors i need? please explain what i am missing… and what connects in to the Raspberry PI.
              Also note the second i want to have outside the home and set up to a facial recog module, and comand it to open the door via face and voice confirm if possibl.
              And how this connects to the a
                amcolash
                If you want a very simple solution (independent of MM completely), check out this script. This is what I am using, it is a very simple python script that reads the value of a PIR and then selectively turns on / off the monitor. You will need to change things up a bit as I wrote it for a C.H.I.P. but the GPIO library is the same.
                cowboysdudeC 1 Reply Last reply Reply Quote 1
                  dmcinnes Module Developer @Guest
                  @wjdw87 cool! The connection is basicly the same as a PIR sensor. It has three wires, ground, vcc, and data which goes high when it senses motion. I plugged it into the PI’s 3.3v, ground and I believe gpio 22 (whichever is the default for the module).
                  Since the wire comes out as a three pin JST I split it into individual header connectors because all the pins are not next to one another on the PI.
                  Hope that helps!
                    rvdgeer
                    Can anyone of you please share a picture of how you’ve connected the microwave sensor to the Pi pins?
                    I know this sounds dumb, but I can’t seem to find out what pin connects to what, as I don’t know what pin is ground and what pins is (data) out…
                    Thanks!
                      cowboysdude Module Developer @amcolash
                      @amcolash said in PIR sensor behind glass?:
                      VERY good choice! Mine also works independent… but I really like your idea!
                      • N Offline
                        Nususu @cowboysdude
                        @cowboysdude I recently picked up these microwave sensor modules to use in conjunction with the code you posted for PIR Sensor. I’m pretty new to all this, and I can’t get any function out of the sensor. Do you have some advice on how to troubleshoot this? It could be an error on my part in implementing the code, wiring it incorrectly, or something else, but I’m just not sure how to figure out what the issue is.
                          cowboysdude Module Developer @Nususu
                          @Nususu I would go online and lookup ‘wiring pir sensor raspberry pi’ there are TONS of things out there. Your issue could be one of any or a combination of things… I did that using a PIR sensor so I have no idea how it would act with microwave sensors… good I’m hoping because I want to get some… BUT let me know if you need anymore help, not that I helped you now but I will do what I can!
                            cowboysdude Module Developer @rvdgeer
                            @rvdgeer and @Nususu
                            Try here!
                            https://www.pubnub.com/blog/2015-06-16-building-a-raspberry-pi-motion-sensor-with-realtime-alerts/
                            • N Offline
                              Nususu @cowboysdude
                              @cowboysdude thanks, I’ll check that out and let you know how it goes!
                              • N Offline
                                Nususu @cowboysdude
                                @cowboysdude I got it working using this code:
                                https://github.com/paviro/MMM-PIR-Sensor
                                With this code, I’ve got a problem where the screen only stays on for about 1 second after motion detection. Now I need to modify the code somehow to allow me to tell the mirror to stay on for a set amount of time after detecting motion, i.e. only go dark once no motion has been detected for x seconds. Problem is I don’t know where to start with that. Will let you know if I figure anything out. Any ideas?
                                  @Nususu try adding the powerSaving to your config…
                                          module: 'MMM-PIR-Sensor',
                                              powerSaving: false
                                  See what that does :) PLUS there’s also an adjustment on your PIR sensor itself… which one and I don’t know … do a google search for adjustments :)
                                    Aly
                                    @Nususu - same here
                                    Perhaps, with a resistor?
                                    • N Offline
                                      Nususu @Aly
                                      @Aly I found documentation for the sensor that a resistor would indeed solve the issue here. I can set the delay up to 200 seconds with a 250k resistor, so I ordered one and will report back how it went.
                                        Aly
                                        @Nususu - great !!
                                        Can you post the doc. ?
                                        • N Offline
                                          Nususu @Aly
                                          @Aly I misspoke, shouldn’t have called it documentation. Rather, it was this picture:alt text
                                          Which appears to be a translation from the Chinese original picture.
                                            Aly @Nususu
                                            @Nususu
                                            so if we remove the R6 resistor the delay would be 30s ?
                                            • 3 / 4
