    MMM-MyTraktSeries
    12 Posts 7 Posters 7.9k Views 7 Watching
    • T Offline
      TheVieiraAkA @retroflex
      @retroflex hum… thats weird, I don’t know if this matter but try to put your Trakt account and custom List public and see if you get anything different. Plz let me know
        @TheVieiraAkA My trakt account was already public. But I found that I was using the default watchlist, which probably wasn’t a good idea. I created a new public list and switched the ID in the config to that one. Still no luck, same error.
        • T Offline
          @retroflex Sorry about the delay
          I recently update the module to fix some errors
          make sure you delete the token.js file in the module, and you have the node_modules installed in my module
          create an app on trakt.tv in here , and assign http://localhost/ to the “Redirect uri:” and “Javascript (cors) origins:”
          Then before you try directlly on the module in the Magic Mirror, use the Trakt API to test it
          1. go Here, and on URI Params, insert your username, and on Headers, put your Client_ID on trakt-api-key option and click Call Resource
            1.1 it should give you a full list of custom lists that you have, search for :
          “ids”: {
          “trakt”: 123456,
          “slug”: “asdvgasvdhasbdabsd”
          1. on the config.js on Magic mirror, in the MMM-MyTraktSeries module, put the “123456” code that you got from the TraktAPI in the step 1 in the id_lista: field
            it should work without a problem
          luisestradaL 1 Reply Last reply Reply Quote 0
            ankurchauhin
            The above module you’ve mentioned above was in a very smooth way and i can able to set up an application, API key + secret and list id. But I get an error with the pop up “enter the following on our official website”! there we can use only the eight digit code and i tried one of my trakt friends suggestion and it worked me a lot, if any one get an error like me you can solve that issue from here.
              dxfan227
              what;s the user name?
              • luisestradaL Offline
                luisestrada @TheVieiraAkA
                @TheVieiraAkA Hello,
                I can’t understand why I use one list and it works but then I select another list and it doesn’t. I made it public, friends, private and nothing works.
                It looks that this module was abandoned, but still works.
                Thank you !!!
                  luisestrada @luisestrada
                  MMM-MyTraktSeries.js:61
                  Uncaught (in promise) TypeError: Cannot read properties of undefined (reading ‘nextEp’)
                  at Class.getDom (MMM-MyTraktSeries.js:61:45)
                  at main.js:113:35
                  at new Promise ()
                  at updateDom (main.js:111:10)
                  at Object.updateDom (main.js:552:4)
                  at Class.updateDom (module.js:358:6)
                  at Class.socketNotificationReceived (MMM-MyTraktSeries.js:101:18)
                  at module.js:245:9
                  at Socket. (socketclient.js:38:4)
                  at Emitter.emit (index.mjs:136:20)
                  Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'nextEp')
                  Row 61 says:
                  title = this.shorten(aux[i].nextEp, 19);
                    sdetweil @luisestrada
                    @luisestrada means aux[i]
                    doesn’t point to an object.
