    Electron taking too much memory and processing
    7 Posts 2 Posters 3.5k Views 4 Watching
    • Y Offline
      yours.mukul
      Below is an image showing processing and memory used by my magic mirror
      Please help me out…!
      ![0_1513329865494_IMG_20171215_132840 (1).jpg](Uploading 100%)
      Command CPU RSS
      electron 33% 109.2MB
      electron 24% 142.6MB
      python 21% 256.2MB
      electron 8% 140.6MB
        Mykle1 Project Sponsor Module Developer @yours.mukul
        @yours.mukul
        https://forum.magicmirror.builders/topic/4684/electron-cpu-usage
        • Y Offline
          yours.mukul @Mykle1
          @Mykle1 I have electron version 1.6.10, can you please tell me how to make it 1.4.15?
          From the provided link I get to know that MMM-2.1.0 and Electron 1.4. 15 is the best combination.
          I’m sorry if my question appears to be very basic, also I cannot do a fresh clean new installation because my Raspberry pi has some of my other projects going on.
          Thank you …
            @yours.mukul said in Electron taking too much memory and processing:
            npm install electron@1.4.15
            I don’t know if installing electron 1.4.15 without MM 2.1.0 will help but I hope so. Please let me know what your results are and good luck.
            • Y Offline
              yours.mukul @Mykle1
              @Mykle1 I already have MM-2.1.0 installed. I just have the electron 1.6.1 So I believe downgrading electron will show some result.
              If I’m not wrong then, the conclusion from the link you posted, was MM-2.1.0 with electron 1.4.5??
              Also if i use npm install @1.4.5,. What will happen with the already installed electron 1.6.1, won’t it clash ???
                @yours.mukul
                You are correct. The determination was that MM v2.1.0 and electron v1.4.15 combination gave the best performance.
                npm install electron@1.4.15 should overwrite the existing electron. If not, you can manually uninstall it before installing 1.4.15
                • Y Offline
                  yours.mukul @Mykle1
                  @Mykle1 should I use this command in ‘MagicMirror/node_modules/’ directory or somewhere else.
                  Also how to uninstall electron manually?
                  I’m sorry if my question is too basic.
