    npm start doesn't work
    3 Posts 2 Posters 1.9k Views 2 Watching
    • T
      Tschanz
      I hope someone is able to help me. If i type npm start the following error message appears:
      > magicmirror@2.1.3 start /home/pi/MagicMirror
      > sh run-start.sh
      run-start.sh: 4: run-start.sh: electron: not found
      npm ERR! magicmirror@2.1.3 start: `sh run-start.sh`
      npm ERR! Exit status 127
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.3 start script.
      npm ERR! This is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     sh run-start.sh
      npm ERR! You can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR! System Linux 4.4.34-v7+
      npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v0.10.29
      npm ERR! npm -v 1.4.21
      npm ERR! code ELIFECYCLE
      npm WARN This failure might be due to the use of legacy binary "node"
      npm WARN For further explanations, please read
      /usr/share/doc/nodejs/README.Debian
      npm ERR!
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      npm ERR! not ok code 0
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Tschanz
        @Tschanz said in npm start doesn’t work:
        You need to update your node which should also update your npm
        • T
          Tschanz
          I have tried :
          $ sudo apt update
          and
          $ sudo apt install nodejs
          But there is still the same error. I hope somebody can help me.:)
