    Need some advise. Digital Ocean Modules
    19 Posts 2 Posters 12.7k Views 2 Watching
      andrewchumchal
      Hello Guys.
      I am currently writing a module for Digital Ocean with MM2. I have all it done expect for the api called. I have seen some other ones but most of them uses a url for the called. DO using a curl not a url. Any help would be thankful.
      PS here is the documentation for it https://www.npmjs.com/package/dropletapi
      • strawberry 3.141S Offline
        can you show what you’ve got so far and what you want to use from the api (e.g. which methods) ?
          andrewchumchal @strawberry 3.141
          @strawberry-3.141 I would like to pull the IP and Name and the Status. and here is a copy of my MMM-Digital-Ocean.js file https://raw.githubusercontent.com/andyipod1437/MMM-Digital-Ocean/master/MMM-Digital-Ocean.js
            this should give you a litte help
            node_helper.js
            const DIGITALOCEAN = require('dropletapi').Droplets;
            const NodeHelper = require('node_helper');
                digitalocean: null,
                start: function() {
                    console.log("Starting module: " + this.name);
                    if (notification === "CONFIG") {
                        this.config = payload;
                        this.digitalocean = new DIGITALOCEAN(this.config.api_key);
                        setInterval(() => {
                            this.getData();
                        }, this.config.updateInterval);
                        this.getData();
                getData: function() {
                    this.digitalocean.listDroplets((error, result) => {
                        if (error) {
                            console.log(error);
                        } else {
                            this.sendSocketNotification("DATA", result);
            MMM-Digital-Ocean.js in start method
            this.sendSocketNotification("CONFIG", this.config);
            in socketNotificationReceived
            if(notification === "DATA"){
                this.droplets = payload;
            in getDom you can iterate over all droplets and build the output you want
              @strawberry-3.141
              where do i add the very last part ?
                strawberry 3.141 Project Sponsor Module Developer @andrewchumchal
                @andrewchumchal also in MMM-Digital-Ocean.js
                  @strawberry-3.141
                  Any where ? or in a function called socketNotificationReceived
                    @andrewchumchal
                    socketNotificationReceived: function(notification, payload){
                    A 2 Replies Last reply Reply Quote 0
                      @strawberry-3.141
                      Thanks again for all of you help. Now I just need to get the getDom to work :)
                        @strawberry-3.141
                        Any ideas where i can start? like where i can get the name and status.
                          @andrewchumchal
                          for(var i = 0; i < this.droplets.droplets.length; i++;){
                              var name = this.droplets.droplets[i].name;
                              var status = this.droplets.droplets[i].status;
                              var ip = '';
                              for(var n = 0; n < this.droplets.droplets[i].networks['v4'].length; n++;){
                                  ip += this.droplets.droplets[i].networks['v4'].ip_address + ' | ';
                              for(var n = 0; n < this.droplets.droplets[i].networks['v6'].length; n++;){
                                  ip += this.droplets.droplets[i].networks['v6'].ip_address + ' | ';
                              ip = ip.replace(/ | $/, '');
                            @strawberry-3.141
                            sorry to bug you so much dose that go in the get dom ?
                              @andrewchumchal this is just how you can access status name and the ip in getDom for example but you still need to render this
                                andrewchumchal
                                This post is deleted!
                                  andrewchumchal
                                  @strawberry-3-141 Hey. I was not able to get it to display it last night. I try everything i could. Any more ideas ?
                                    @andrewchumchal
                                    getDom: function() {
                                        if(this.droplets){
                                            var table = document.createElement("table");
                                            for(var i = 0; i < this.droplets.droplets.length; i++){
                                                var row = document.createElement("tr");
                                                var name = document.createElement("td");
                                                name.innerHTML = this.droplets.droplets[i].name;
                                                row.appendChild(name);
                                                var status = document.createElement("td");
                                                status.innerHTML = this.droplets.droplets[i].status;
                                                row.appendChild(status);
                                                var ips = '';
                                                    ips += this.droplets.droplets[i].networks['v4'][n].ip_address + ' | ';
                                                    ips += this.droplets.droplets[i].networks['v6'][n].ip_address + ' | ';
                                                ips = ips.replace(/ | $/, '');
                                                var ip = document.createElement("td");
                                                ip.innerHTML = ips;
                                                row.appendChild(ip);
                                                table.appendChild(row);
                                            wrapper.appendChild(table);
                                        } else {
                                            wrapper.innerHTML = "No data to show!";
                                        return wrapper;
                                      @strawberry-3.141
                                      I just update my code.
                                      And i have a droplet created but it shows no data to show ?
                                        @andrewchumchal this is all untested and should give you just a direction on how it could be solved. make sure you update the dom when receiving data
                                               this.updateDom();
                                          andrewchumchal
                                          Thanks you so much @strawberry-3-141.
