    Need some advise. Digital Ocean Modules
    19 Posts 2 Posters 12.1k Views 2 Watching
    • strawberry 3.141S Offline
      this should give you a litte help
      node_helper.js
      const DIGITALOCEAN = require('dropletapi').Droplets;
      const NodeHelper = require('node_helper');
          digitalocean: null,
          start: function() {
              console.log("Starting module: " + this.name);
              if (notification === "CONFIG") {
                  this.config = payload;
                  this.digitalocean = new DIGITALOCEAN(this.config.api_key);
                  setInterval(() => {
                      this.getData();
                  }, this.config.updateInterval);
                  this.getData();
          getData: function() {
              this.digitalocean.listDroplets((error, result) => {
                  if (error) {
                      console.log(error);
                  } else {
                      this.sendSocketNotification("DATA", result);
      MMM-Digital-Ocean.js in start method
      this.sendSocketNotification("CONFIG", this.config);
      in socketNotificationReceived
      if(notification === "DATA"){
          this.droplets = payload;
      in getDom you can iterate over all droplets and build the output you want
      andrewchumchalA 1 Reply Last reply Reply Quote 0
      • andrewchumchalA Offline
        andrewchumchal @strawberry 3.141
        @strawberry-3.141
        where do i add the very last part ?
          strawberry 3.141 Project Sponsor Module Developer @andrewchumchal
          @andrewchumchal also in MMM-Digital-Ocean.js
            @strawberry-3.141
            Any where ? or in a function called socketNotificationReceived
              @andrewchumchal
              socketNotificationReceived: function(notification, payload){
              andrewchumchalA 2 Replies Last reply Reply Quote 0
                @strawberry-3.141
                Thanks again for all of you help. Now I just need to get the getDom to work :)
                  @strawberry-3.141
                  Any ideas where i can start? like where i can get the name and status.
                    @andrewchumchal
                    for(var i = 0; i < this.droplets.droplets.length; i++;){
                        var name = this.droplets.droplets[i].name;
                        var status = this.droplets.droplets[i].status;
                        var ip = '';
                        for(var n = 0; n < this.droplets.droplets[i].networks['v4'].length; n++;){
                            ip += this.droplets.droplets[i].networks['v4'].ip_address + ' | ';
                        for(var n = 0; n < this.droplets.droplets[i].networks['v6'].length; n++;){
                            ip += this.droplets.droplets[i].networks['v6'].ip_address + ' | ';
                        ip = ip.replace(/ | $/, '');
                      @strawberry-3.141
                      sorry to bug you so much dose that go in the get dom ?
                        @andrewchumchal this is just how you can access status name and the ip in getDom for example but you still need to render this
