Need some advise. Digital Ocean Modules
19 Posts 2 Posters 10.3k Views 2 Watching
    andrewchumchal
    Hello Guys.
    I am currently writing a module for Digital Ocean with MM2. I have all it done expect for the api called. I have seen some other ones but most of them uses a url for the called. DO using a curl not a url. Any help would be thankful.
    PS here is the documentation for it https://www.npmjs.com/package/dropletapi
      can you show what you’ve got so far and what you want to use from the api (e.g. which methods) ?
      A 1 Reply Last reply Sep 8, 2016, 8:15 PM Reply Quote 0
        andrewchumchal @strawberry 3.141
        @strawberry-3.141 I would like to pull the IP and Name and the Status. and here is a copy of my MMM-Digital-Ocean.js file https://raw.githubusercontent.com/andyipod1437/MMM-Digital-Ocean/master/MMM-Digital-Ocean.js
          this should give you a litte help
          node_helper.js
          const DIGITALOCEAN = require('dropletapi').Droplets;
          const NodeHelper = require('node_helper');
              digitalocean: null,
              start: function() {
                  console.log("Starting module: " + this.name);
                  if (notification === "CONFIG") {
                      this.config = payload;
                      this.digitalocean = new DIGITALOCEAN(this.config.api_key);
                      setInterval(() => {
                          this.getData();
                      }, this.config.updateInterval);
                      this.getData();
              getData: function() {
                  this.digitalocean.listDroplets((error, result) => {
                      if (error) {
                          console.log(error);
                      } else {
                          this.sendSocketNotification("DATA", result);
          MMM-Digital-Ocean.js in start method
          this.sendSocketNotification("CONFIG", this.config);
          in socketNotificationReceived
          if(notification === "DATA"){
              this.droplets = payload;
          in getDom you can iterate over all droplets and build the output you want
          A 1 Reply Last reply Sep 8, 2016, 9:21 PM Reply Quote 0
            @strawberry-3.141
            where do i add the very last part ?
            S 1 Reply Last reply Sep 8, 2016, 9:22 PM Reply Quote 0
              strawberry 3.141 Project Sponsor Module Developer @andrewchumchal
              @andrewchumchal also in MMM-Digital-Ocean.js
              A 1 Reply Last reply Sep 8, 2016, 9:24 PM Reply Quote 0
                @strawberry-3.141
                Any where ? or in a function called socketNotificationReceived
                S 1 Reply Last reply Sep 8, 2016, 9:26 PM Reply Quote 0
                  @andrewchumchal
                  socketNotificationReceived: function(notification, payload){
                  A 2 Replies Last reply Sep 8, 2016, 9:29 PM Reply Quote 0
                    @strawberry-3.141
                    Thanks again for all of you help. Now I just need to get the getDom to work :)
                      @strawberry-3.141
                      Any ideas where i can start? like where i can get the name and status.
                      S 1 Reply Last reply Sep 8, 2016, 10:27 PM Reply Quote 0
