    Need some advise. Digital Ocean Modules
    19 Posts 2 Posters 11.9k Views 2 Watching
    • andrewchumchalA Offline
      andrewchumchal
      Hello Guys.
      I am currently writing a module for Digital Ocean with MM2. I have all it done expect for the api called. I have seen some other ones but most of them uses a url for the called. DO using a curl not a url. Any help would be thankful.
      PS here is the documentation for it https://www.npmjs.com/package/dropletapi
      • strawberry 3.141S Offline
        can you show what you’ve got so far and what you want to use from the api (e.g. which methods) ?
        andrewchumchalA 1 Reply Last reply Reply Quote 0
          andrewchumchal @strawberry 3.141
          @strawberry-3.141 I would like to pull the IP and Name and the Status. and here is a copy of my MMM-Digital-Ocean.js file https://raw.githubusercontent.com/andyipod1437/MMM-Digital-Ocean/master/MMM-Digital-Ocean.js
            this should give you a litte help
            node_helper.js
            const DIGITALOCEAN = require('dropletapi').Droplets;
            const NodeHelper = require('node_helper');
                digitalocean: null,
                start: function() {
                    console.log("Starting module: " + this.name);
                    if (notification === "CONFIG") {
                        this.config = payload;
                        this.digitalocean = new DIGITALOCEAN(this.config.api_key);
                        setInterval(() => {
                            this.getData();
                        }, this.config.updateInterval);
                        this.getData();
                getData: function() {
                    this.digitalocean.listDroplets((error, result) => {
                        if (error) {
                            console.log(error);
                        } else {
                            this.sendSocketNotification("DATA", result);
            MMM-Digital-Ocean.js in start method
            this.sendSocketNotification("CONFIG", this.config);
            in socketNotificationReceived
            if(notification === "DATA"){
                this.droplets = payload;
            in getDom you can iterate over all droplets and build the output you want
              @strawberry-3.141
              where do i add the very last part ?
                strawberry 3.141 Project Sponsor Module Developer @andrewchumchal
                @andrewchumchal also in MMM-Digital-Ocean.js
                  @strawberry-3.141
                  Any where ? or in a function called socketNotificationReceived
                    @andrewchumchal
                    socketNotificationReceived: function(notification, payload){
                    andrewchumchalA 2 Replies Last reply Reply Quote 0
                      @strawberry-3.141
                      Thanks again for all of you help. Now I just need to get the getDom to work :)
                        @strawberry-3.141
                        Any ideas where i can start? like where i can get the name and status.
