    Rainalarm (Buienalarm in Dutch)
    25 Posts 4 Posters 18.1k Views 4 Watching
    • P
      Peter
      Can anybody help me to get this working on a MM:
      https://gist.github.com/jdennes/61322ea392df9120396eb6651f64e566
      Rain is a daily problem in the Netherlands, so it would be very nice to have an alarm for it on my MM.
      Peter
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Peter
        @Peter said in Rainalarm (Buienalarm in Dutch):
        Are you talking about creating an entire module?
        You could use one of the iFrame modules and load the link http://www.buienalarm.nl/location/rotterdam into the iFrame. I haven’t done this but it seems like the perfect solution, unless you want to make a module of your own.
        • P
          Peter
          I can not create a module myself, that’s why I asked for help.
          No idea how to start, but it just would be nice to have on the screen of the MM.
          Peter
          • Mykle1M
            @Peter
            Give this a try, Peter.
            https://github.com/alberttwong/MMM-iFrame
            P 1 Reply Last reply
            • P
              Peter @Mykle1
              @Mykle1 , I will give it a try!
              Thanks again.
              Peter
              • cirdanC
                cirdan
                I made one based on the dutch buienradar api, icw sparkline js. Can upload it to github if you like. It’s a 2 hour forecast graph based on longitude/latitude
                Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
                Mykle1M P 2 Replies Last reply
                Reply Quote 1
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @cirdan
                  @cirdan
                  Cirdan! Elen síla lúmenn’ omentielvo :-)
                  cirdanC 1 Reply Last reply
                  Reply Quote 1
                  • P
                    Peter @cirdan
                    @cirdan , that would be great!
                    I love this forum.
                    Peter
                    • cirdanC
                      cirdan @Mykle1
                      @Mykle1 Not if it rains, Mykle, let me check my MM, ahh clear skies ;-)
                      Reply Quote 1
                      • cirdanC
                        cirdan @Peter
                        @Peter I added it under https://github.com/73cirdan/MMM-rainfc,
                        (should run ok, but did some last minute code cleanups.)
                        Let me know how it works out for you
                        P lavolp3L 2 Replies Last reply
                        • P
                          Peter @cirdan
                          @cirdan , it works out of the box.
                          But unfortunally it does not show the (current) time, so it is hard to see when the rain starts and stops.
                          Thanks for your help!
                          Peter
                          • cirdanC
                            cirdan
                            The current time is in the clock module, so i considered it double info. The graph is always 2 hours, end time is shown, so you need to interpolate a little. Alternative is to add some tick marks under the graph with timelabels. I think it’s possible but never looked into it.
                            • P
                              Peter @cirdan
                              @cirdan , some timelines would be nice (like in the smartphone app).
                              Maybe some day somebody knows how to do this.
                              Thanks.
                              Peter
                              • cirdanC
                                cirdan @Peter
                                @Peter, I checked the sparkline.js lib I use for the graph. It intentional does not use ticks and labels on the x axis. :-(
                                • P
                                  Peter @cirdan
                                  @cirdan , thanks.
                                  Bad luck.
                                  Peter
                                  • cirdanC
                                    cirdan @Peter
                                    @Peter Did a small addition with time labels under the graph. checked it in on github.
                                    Reply Quote 1
                                    • P
                                      Peter @cirdan
                                      @cirdan , I only see the graph, not the time labels.
                                      Peter
                                      • cirdanC
                                        cirdan
                                        There is a new config option, its in the readme on github. Add nrOfTimeLabels to your config.js and it should work.
                                        • P
                                          Peter @cirdan
                                          @cirdan unfortunately it does not work.
                                          Changed color, changed lon-lat, works all fine, but not the time labels.
                                          Very sorry …
                                          Peter
                                          • cirdanC
                                            cirdan @Peter
                                            @Peter just checking, you’ve pulled the new source from github?
                                            Like a git pull or git clone?
