    Rainalarm (Buienalarm in Dutch)
    25 Posts 4 Posters 18.1k Views 4 Watching
      Peter @Mykle1
      @Mykle1 , I will give it a try!
      Thanks again.
      Peter
      • cirdanC
        cirdan
        I made one based on the dutch buienradar api, icw sparkline js. Can upload it to github if you like. It’s a 2 hour forecast graph based on longitude/latitude
        Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
        Mykle1M P 2 Replies Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @cirdan
          @cirdan
          Cirdan! Elen síla lúmenn’ omentielvo :-)
          cirdanC 1 Reply Last reply
            Peter @cirdan
            @cirdan , that would be great!
            I love this forum.
            Peter
            • cirdanC
              cirdan @Mykle1
              @Mykle1 Not if it rains, Mykle, let me check my MM, ahh clear skies ;-)
              • cirdanC
                cirdan @Peter
                @Peter I added it under https://github.com/73cirdan/MMM-rainfc,
                (should run ok, but did some last minute code cleanups.)
                Let me know how it works out for you
                P lavolp3L 2 Replies Last reply
                  Peter @cirdan
                  @cirdan , it works out of the box.
                  But unfortunally it does not show the (current) time, so it is hard to see when the rain starts and stops.
                  Thanks for your help!
                  Peter
                  • cirdanC
                    cirdan
                    The current time is in the clock module, so i considered it double info. The graph is always 2 hours, end time is shown, so you need to interpolate a little. Alternative is to add some tick marks under the graph with timelabels. I think it’s possible but never looked into it.
                    P 1 Reply Last reply
                      Peter @cirdan
                      @cirdan , some timelines would be nice (like in the smartphone app).
                      Maybe some day somebody knows how to do this.
                      Thanks.
                      Peter
                      • cirdanC
                        cirdan @Peter
                        @Peter, I checked the sparkline.js lib I use for the graph. It intentional does not use ticks and labels on the x axis. :-(
                          Peter @cirdan
                          @cirdan , thanks.
                          Bad luck.
                          Peter
                          • cirdanC
                            cirdan @Peter
                            @Peter Did a small addition with time labels under the graph. checked it in on github.
                              Peter @cirdan
                              @cirdan , I only see the graph, not the time labels.
                              Peter
                              • cirdanC
                                cirdan
                                There is a new config option, its in the readme on github. Add nrOfTimeLabels to your config.js and it should work.
                                  Peter @cirdan
                                  @cirdan unfortunately it does not work.
                                  Changed color, changed lon-lat, works all fine, but not the time labels.
                                  Very sorry …
                                  Peter
                                  • cirdanC
                                    cirdan @Peter
                                    @Peter just checking, you’ve pulled the new source from github?
                                    Like a git pull or git clone?
                                      Peter @cirdan
                                      @cirdan sorry; after having done that it works!
                                      Thanks!
                                      Peter
                                      • cirdanC
                                        cirdan @Peter
                                        @Peter great, i’m glad it works
                                        • lavolp3L
                                          lavolp3 Module Developer @cirdan
                                          @cirdan
                                          Hi cirdan,
                                          I’d like to say THANK YOU for the module. I was searching for this for about a year now, also made a thread here asking for it.
                                          Let me also say, this also works for parts of Germany close to the Netherlands (I live close to Duisburg).
                                          I would suggest to present this in the “modules” section for more recognition.
                                          I’d also like to contribute to it, thinking about the possibility for users to show bar graphs or line graphs.
                                          Will send a pull request on github when successful.
                                          How to troubleshoot modules
                                          MMM-soccer v2, MMM-AVStock
                                          Mykle1M cirdanC 2 Replies Last reply
                                          Reply Quote 2
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @lavolp3
                                            @lavolp3 said in Rainalarm (Buienalarm in Dutch):
                                            Awesome! :-)
