    Slim, Frameless Bathroom Mirror with a 27" Display
    42 Posts 15 Posters 60.3k Views 24 Watching
      reaper81
      Hello everybody,
      Since I came across the DIY Smartmirror project of Micheal Teuw and this forum about 1.5 years ago, I really wanted to build one myself. The project started on December 25, 2016 with the purchase of a Raspis and after almost one year it has been hanging on the wall since January 2, 2018. I’m curious if and how he proves himself in everyday life.
      The main goal was to build as lean and frameless mirror as possible, which requires no control in everyday life.
      The mirror has the following functions:
      Indirect lighting with dimming function and color temperature selection from 6500K -2700K
      Bluetooth speakers with exciters that stimulate the glass surface instead of a membrane
      Radar motion detector that turns the display on and off
      Smart Mirror modules:
      Weather
      date
      Events
      News Feed
      fuel prices
      Personal Greeting
      Travel times public transport
      Face recognition for user profile control
      IMG_20171114_210558
      My main problems with the project were:
      To find a provider for the spy mirror
      To find the largest possible TV or display, which is very narrow and down-facing ports
      To get a reasonably functioning facial recognition. The detection rate is mediocre
      To find a motion detector that detects through metallized glass
      Here are some steps in the process of getting started:
      The project stood and fell with a German provider for the PILKINGTON MIRROPANE which was advertised in the forum and many tests as the best. I chose a thickness of 4mm and a size of 1.5m x 0.8m with rounded corners and edges.
      IMG_20170818_WA0007
      After the bi-annual research for the mirror, the search for the right screen was hardly shorter. Although I would liked to have an even larger display but the AOC is ideal from its nature with max only 2 cm depth.
      IMG_20170729_104150
      The separate power supply makes disassembly of the screen unnecessary. Only the foot must be unscrewed.
      The frame was built with square wood from the hardware store in the size 3.8 cm. Thus, nothing in the mirror should have a depth greater than 3.8 cm. The beams were dowelled, pegged and glued.
      IMG_20170910_123753
      For attachment to the wall without columns but with adjustment I have made hanging bars. Alternatively, there are now IKEA rails with adjustment options.
      IMG_20170822_151740
      IMG_20170919_201242
      IMG_20170923_180256
      On the cheap Amazon Bluetoothlautsprecher the speakers were removed and replaced by exciters, which bring the mirror surface to vibrate instead of a membrane. The battery was replaced by a 5V power supply that also powers the Raspi.
      IMG_20171004_201045
      For indirect lighting special 45 ° aluminum profiles were used, into which the LED strips were laid. The lighting can be dimmed and set the color temperature by radio.
      IMG_20171021_202318
      IMG_20171029_200307
      As I later discovered, neither the PIR sensor nor the radar sensor detects through a mirror. But since the radar sensor does not need a Fresnel cover to detect at wide angle, I kept using it. So that anything can be detected, I had to drill a hole in the mirror.
      IMG_20171119_150053
      IMG_20171119_151308
      IMG_20171119_151413
      Yes, that was just as exciting as it sounds.
      Behind the hole came the sensor and before that a cover. Becuase the plastic covers did not look good enough, I used a metal one. Although this lowers the detection performance but looks classy. The sensor now works more as a touch sensor but the compromise on the optics was worth it.
      I am satisfied with the final result.
      IMG_20180102_220335
      IMG_20180102_220359
      Cr4z33C 1 Reply Last reply Reply Quote 13
        doubleT Module Developer
        Wow, that looks classy, nice job!
        @reaper81 said in Slim, Frameless Bathroom Mirror with a 27" Display:
        Too late now, but I’d have suggested using only two of the three power sockets and building a cover with the PIR sensor for the socket in the middle. You probably get your power for the mirror from a hidden cable in the wall from there anyway? Or under the counter?
          MyMirror
          @reaper81:
          What kind of PIR do you use? Maybe a HC-SR501?
          And what happens, if the screen comes back from standby? Did a message e. g. “HDMI” or similar appear on the screen?
            reaper81
            @doubleT
            During the bathroom planning was only a backlit mirror planned with cable for light.
            This we have reconnected to continuous current. An surface-mounted shaft would never be an option.
              reaper81
              @MyMirror
              I do not use a PIR sensor. I use the RCWL-0516 radar sensor. It is PIN compatible too the standard PIR sensors and cheap. However, if you connect it upside down, it burns immediately. That happened to me twice.
                bhepler Module Developer
                Fantastic job, @reaper81. That looks like a professional installation.
                  schlachtkreuzer6
                  Looks great! :)
                  What rails do you use (link)? That seems to be a really nice idea!
                    reaper81
                    @schlachtkreuzer6
                    if you mean the aluminum profile, they are from led-konzept. A realy nice shop, with lots of ideas all around led.
                      schlachtkreuzer6 @reaper81
                      @schlachtkreuzer6
                      No^^the parts for hanging, with the adjustment option from ikea :)
                        reaper81
                        @schlachtkreuzer6
                        the conzept is called frence cleat. if they are well done, you can hang your mirror on the wall whitout any gap.
                        alt text
                        my rails are handcrafted and not so good.
                        alt text
                        alt text
                        My timber was too thick for the circular saw. If you use the ikea besta rails it is much easier and you get probably better results.
                          @reaper81
                          Ah I see. Thanks!
                            Relic
                            This looks like exactly what I want to do! I have one question though, how did you attach the wood frame to the glass? Looks great btw:)
                              MyMirror
                              Hi reaper81,
                              same question from my site:
                              how did you attach the mirror to the wooden frame to make it look frameless? Can you provide us some pictures and tipps?
                                MyMirror
                                One more :-)
                                Can you explain the first picture a bit more? What are the individual boxes and connections that can be seen in the picture?
                                  reaper81
                                  @Relic
                                  The wood frame ist glued with the strongest intallation glue i could find. in my case it was soudal fix all high track.
                                  The consistency of this glue is very tough, so i had to spread it with a spatula on the frame. Before this i had roughen the foil on the glas with sandpaperfor more gluegrip.
                                  alt text
                                  alt text
                                  After one day with a lot of weight on the frame the glue was harden.
                                    reaper81
                                    @ MyMirror
                                    Before finishing the project, i had to rearange some prarts a little bit of the mirror, because i needed some space for the hanging rails. So don’t wonder.
                                    alt text
                                    1. 220V AC Connection
                                    2. 220V AC Mainswitch
                                    3. 220V AC branching dose
                                    4. 24V LED-power adapter
                                    5. LED-Controller with radioreceiver
                                    6. LED-stripes
                                    7. monitor-power adapter mit HDMI-connection
                                    8. monitor
                                    9. 5V power adapter for Raspberry Pi und Bluetooth-Speaker
                                    10. raspberry Pi
                                    11. networkcable for Raspberry Pi
                                    12. cameramodul for useridentification
                                    13. radarsensor zur userdetection
                                    14. voltage converter für Bluetooth-speaker from 5V to 3.3V
                                    15. bluetoothreceiver/ -amplifier für exciter
                                    16. button zur connect Bluetoothreceiver und smartphone
                                    17. volumen Up Button for the Bluetoothreceiver
                                    18. volumen Down Button for the Bluetoothreceiver
                                    19. exciter (speaker)
                                    20. memorycard for the raspi with a backupimage
                                    • V Offline
                                      Vancete
                                      WOW. It look georgeous.
                                        MyMirror
                                        Very good - thanks for sharing!
                                          schlachtkreuzer6
                                          Thank you for all your informations! So last question ^^ how is the sound with the exciters? Maybe we need here a YouTube video 😁😁
                                            MyMirror
                                            … and a few more from my site :-)
                                            • Can you show us, how do you dismantled the foot
                                              and how do you attach the power cable on the screen?
                                            • What about the temperature of the monitor? Will not be too hot in the tight construction?
                                            • Do you apply black foil on the back side of the mirror to improve the mirror effect?
                                            Thanks for all your tips and pictures!
                                            • 1 / 3
