    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 349.1k Views 54 Watching
    • P Offline
      Peter Leemon
      Hi all have followed step 2.1 got my tv to turn off and back on ok but doesn’t stay on for long at all (only a few seconds)?
      • F Offline
        FREIGHTTRAIN
        This post is deleted!
        FoziF 1 Reply Last reply Reply Quote 0
        • FoziF Offline
          Fozi Project Sponsor @FREIGHTTRAIN
          @FREIGHTTRAIN Can you elaborate more precisely, what is not working? What have you done? What is the expected behaviour? How does it behave? How to reproduce? That might help in helping you.
            drk-geek @cruunnerr
            hi @cruunnerr
            I just installed it, everything looks good but not working at all. I tried via 2.1 Using PIR-Module and 2.2 Using PIR-Script both not working, any suggestion how to check where the issue is?
              deebee999 @cruunnerr
              @cruunnerr
              I have had success with your help and my PIR sensor but only after running pir.py from .bashrc
              The script is working however I read the following warning when accessing my Magic Mirror with SSH:
              RuntimeWarning. This channel is already in use, continuing anyway. io.setup(LED_PIN, io.OUT)
              My end result is not affected. The PIR works fine.
              Thank you
                maptecnet
                Just a little feedback that was a huge help for me.
                @cruunnerr don’t know if you want to add this information on your first message.
                I have a samsung d6000 series tv that wouldn’t work anyway with modules for PIR sensor. A BIG aplause for all developers but i coudn’t get the tv out of “No Signal” message. The MagicMirror would turn image off but tv only in “No Signal”.
                I’m not a programmer and just went on test and try.
                I figured out that the https://github.com/bugsounet/MMM-NewPIR from @Bugsounet (BIG thanks to you also!) managed the problem!!
                With this module set to mode: 4 - use HDMI CEC the TV shuts down when the MagicMirror tells her to shut down!
                It’s straight through ON and OFF as expected!
                I’me very thankful to you all managing to help us out!
                Thanks!
                • U Offline
                  ulster
                  @cruunnerr
                  its possible to kill 2.2 Using PIR-Script in rasp pi?
                  Can you tell me how I cans do it please?
                  thanks
                    sdetweil @ulster
                    @ulster kill 2.2 what?
                    U 1 Reply Last reply Reply Quote 0
                    • U Offline
                      ulster @sdetweil
                      This one. Mentioned in the first page.
                      how to remove it?
                      #!/usr/bin/env python
                      import sys
                      import time
                      import RPi.GPIO as io
                      import subprocess
                      io.setmode(io.BCM)
                      SHUTOFF_DELAY = 120 # in seconds, how long the monitor will be on until next button press or PIR detection
                      PIR_PIN = 22 # 15 on the board (this needn’t to be a PIR. Can be a button also)
                      LED_PIN = 16 # optional, don’t use as Relay-PIN. It just shows detection time of the PIR without delay time
                      def main():
                      io.setup(PIR_PIN, io.IN)
                      turned_off = False
                      last_motion_time = time.time()
                      while True:
                          if io.input(PIR_PIN):
                              io.output(LED_PIN, io.LOW)
                              print ".",
                              sys.stdout.flush()
                              if turned_off:
                                  turned_off = False
                                  turn_on()
                          else:
                              if not turned_off and time.time() > (last_motion_time +
        SHUTOFF_DELAY):
                                  turned_off = True
                                  turn_off()
                              if not turned_off and time.time() > (last_motion_time + 1):
                                  io.output(LED_PIN, io.HIGH)
                          time.sleep(.1)
                      def turn_on():
                      subprocess.call(“sh /home/pi/monitor_on.sh”, shell=True)
                      def turn_off():
                      subprocess.call(“sh /home/pi/monitor_off.sh”, shell=True)
                      if name == ‘main’:
                      try:
                      main()
                      except KeyboardInterrupt:
                      io.cleanup()
                        sdetweil @ulster
                        @ulster sorry, i dont know anything about the module and dont read ( or re-read) every page of posts
                          andi.aw.weiss
                          Hello everyone, I’m getting desperate. I’ve now read the entire tutorial but I can’t find my mistake.
                          I am using my MM with a PIR sensor and would like to switch the backlight of the display with a relay. so i use this script pir.py:
                          import sys
                          import time
                          import subprocess
                          io.setmode(io.BCM)
                          PIR_PIN = 22       # 15 on the board (this needn't to be a PIR. Can be a button also)
                          def main():
                              turned_off = False
                              while True:
                                      print ".",
                                      sys.stdout.flush()
                                      if turned_off:
                                          turned_off = False
                                          turn_on()
                                  else:
        SHUTOFF_DELAY):
                                          turned_off = True
                                          turn_off()
                                  time.sleep(.1)
                          def turn_on():
                          	subprocess.call("sh /home/pi/monitor_on.sh", shell=True)
                          def turn_off():
                          	subprocess.call("sh /home/pi/monitor_off.sh", shell=True)
                          if __name__ == '__main__':
                              try:
                                  main()
                                  io.cleanup()
                          Unfortunately, when I run this script in the terminal, I only get the feedback from the PIR sensor (…) but the relay is not switched. But if I run the monitor_on.sh or monitor_off.sh script it works:
                          monitor_on.sh
                          gpio -g mode 27 out
                          sleep 0.2
                          gpio -g write 27 1
                          monitor_off.sh
                          gpio -g mode 27 out
                          sleep 0.2
                          gpio -g write 27 0
                          But the PIR.py doesn’t work. Where could the mistake lie?
                          Many greetings Andreas
                            MadScientist @andi.aw.weiss
                            @andi-aw-weiss I think you are using the wrong script. With just a quick look it seems you’re running the script from point 2.2 (Using PIR script) of the first post. What you want is point 5.2 (Use relay with a PIR). That script used in 5.2 is different than that of 2.2, which does not have code to control the relay.
                            Have a look at it again.
                            A 2 Replies Last reply Reply Quote 0
                              andi.aw.weiss @MadScientist
                              @MadScientist Hey, unfortunately the problem hasn’t changed. I have now like you said the script from 5.2. The problem remains. PIR detects motion. Relay does not switch. :loudly_crying_face: I don’t know
                                @MadScientist ok it seems to be working now. However, the relay switches the first time after the 120 s have expired and a movement is detected. not previously. The change quote: “io.output(RELAY_PIN, False)” and for monitor off “io.output(RELAY_PIN, True)” only causes the relay to work in reverse. I now use this script:
                                import sys
                                import time
                                import subprocess
                                io.setmode(io.BCM)
                                LED_PIN = 17    # 11 on the board (optional): It just shows detection time of PIR without delay time
                                RELAY_PIN = 27  # 13 on the board
                                def main():
                                    io.setup(RELAY_PIN, io.OUT)
                                    turned_off = False
                                    while True:
                                            print ("."),
                                            sys.stdout.flush()
                                            if turned_off:
                                                turned_off = False
                                                turn_on()
                                        else:
        SHUTOFF_DELAY):
                                                turned_off = True
                                                turn_off()
                                        time.sleep(.1)
                                def turn_on():
                                def turn_off():
                                    try:
                                        main()
                                        io.cleanup()
                                where could the error lie? or is that how it should be? Thank you MadScientist
                                cruunnerrC M 2 Replies Last reply Reply Quote 0
                                • cruunnerrC Offline
                                  cruunnerr @andi.aw.weiss
                                  @andi-aw-weiss
                                  Hey hey,
                                  So what exactly doesn’t work? My English isn’t the best
                                  In my case I am turning on a LED Stripe with the pir.
                                  When I cold start the raspi, the LED stripe turns on for a few seconds (could be the turnoff delay time).
                                  After a while it turns off.
                                  From this moment on it should work as you expect. When movement is detected, the led (or relay) turns on for the delay time and extend the delay time for every new movement within the original delay time.
                                    @andi-aw-weiss said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
                                    Are you saying the screen turns off when the PIR detects a motion? In that case you have to change the the terminals on the relay. You have three terminals to connect the wires to. GND, normal open and normal close.
                                    Another note: I have a bunch of relays here that are supposed to be compatibles with Raspberry Pi’s but somehow they don’t properly work. They switch exactly once and then are stuck. Not sure if you’re having the same issues.
                                      andi.aw.weiss @cruunnerr
                                      @cruunnerr @MadScientist Thanks to both of you . For development/tutorial and support. My MM works. I was probably impatient the whole time I was testing. The relay only switches for the first time after the 120 s have expired. But that’s ok that it only occurs when you restart. I consider the problem solved. THANK YOU
                                      • N Offline
                                        nowayto
                                        Hello, I know this is an old topic but I think it’s very interesting.
                                        I have an idea but I’m a newbie to programming.
                                        In my mind I was thinking about using one or more modules like these:
                                        MMM-ModuleScheduler
                                        MMM-Home-Presence
                                        MMM-RemoteControl
                                        to have a way to turning off the monitor when one member of the family is at home.
                                        For “is at home” I mean when the phone is connected to wifi and the MMM-Home-Presence detect his presence.
                                        Might be MMM-RemoteControl could communicate with MMM-Home-Presence and turn off/on the monitor?
                                        What do you think about it?
                                          sdetweil @nowayto
                                          @nowayto you CAN compose a solution like that.
                                          However Home-Presence does not inform other modules about state of devices
                                          It could’ve extended to do that
                                          Then you could config Remote-Controlto respond to that
                                          • N Offline
                                            nowayto @sdetweil
                                            @sdetweil ok, I don’t think a newbie like me could do it but it was a good idea, if only Home-Presence had a notification option by default. Thanks
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 8 / 9
