    Changing compliments
    49 Posts 9 Posters 42.8k Views 9 Watching
      Stacy @Mykle1
      @Mykle1 Okay. We finally figured it out. We made an external join file for new compliments and that worked. Thank you all SOuch for your help.
        Well done! :-)
          AliAS
          External join file? Lol, thats way outta my league.
            AliAS
            Does anybody know how to use a line break within a compliment? I’ve tried about a dozen different ways to no avail.
              doubleT Module Developer @AliAS
              @AliAS
              Compliments are included via document.createTextNode(complimentText); which doesn’t allow HTML inside.
              But you can change the line within getDom: function() {} that includes the compliment from
              wrapper.appendChild(compliment);
              to
              wrapper.innerHTML = complimentText;
              and then just add a <br /> to the compliment.
              A 1 Reply Last reply Reply Quote 3
                AliAS
                I see. I’ll give it a try. Thank you very much.
                  AliAS @doubleT
                  @doubleT That worked perfect. Thanks again!
                  • K Offline
                    KC5RIL
                    Oh, great! Another noob needs help configuring the Compliments module. I’ve sussed through this for two days trying to get this up and running to earn ‘cool dad points.’ I’ve followed along and made changes to the config.js file as described. When I run ‘npm start’ I get the following: ```
                    code_text
                    > magicmirror@2.12.0 start /home/pi/MagicMirror
                    [2020-08-19 20:06:47.257] [LOG]    Starting MagicMirror: v2.12.0
                    [2020-08-19 20:06:47.264] [LOG]    Loading config ...
                    [2020-08-19 20:06:47.268] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:68
                    SyntaxError: Unexpected identifier
                        at Module._compile (internal/modules/cjs/loader.js:722:23)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                        at Module.load (internal/modules/cjs/loader.js:645:32)
                        at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                        at Module.require (internal/modules/cjs/loader.js:685:19)
                        at require (internal/modules/cjs/helpers.js:16:16)
                        at loadConfig (/home/pi/MagicMirror/js/app.js:67:12)
                        at App.start (/home/pi/MagicMirror/js/app.js:202:3)
                        at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:126:7)
                        at Module._compile (internal/modules/cjs/loader.js:786:30)
                    [2020-08-19 20:06:47.269] [LOG]    Loading module helpers ...
                    [2020-08-19 20:06:47.317] [LOG]    Initializing new module helper ...
                    [2020-08-19 20:06:47.318] [LOG]    Module helper loaded: updatenotification
                    [2020-08-19 20:06:47.321] [LOG]    No helper found for module: helloworld.
                    [2020-08-19 20:06:47.322] [LOG]    All module helpers loaded.
                    [2020-08-19 20:06:47.445] [LOG]    Starting server on port 8080 ...
                    [2020-08-19 20:06:47.458] [LOG]    Server started ...
                    [2020-08-19 20:06:47.459] [LOG]    Connecting socket for: updatenotification
                    [2020-08-19 20:06:47.460] [LOG]    Sockets connected & modules started ...
                    [2020-08-19 20:06:47.556] [LOG]    Launching application.
                    What am I looking at? And how can I correct? Bear with a middle aged noob. You might have to explain this in crayon. Thanks for the help.
                    Mykle1M S 2 Replies Last reply Reply Quote 0
                      Mykle1 Project Sponsor Module Developer @KC5RIL
                      @KC5RIL
                      Post your config entry for compliments in a code block
                        sdetweil @KC5RIL
                        @KC5RIL > Unexpected identifier
                        90% of the time this means a comma missing on the line above
                        K 1 Reply Last reply Reply Quote 1
                        • 4 / 5
