    Could use some assistance setting up MMM-Carousel w/ Navigation and understanding the architecture
    carouselmmm-carouselnavigationslidepage
    27 Posts 9 Posters 17.8k Views 9 Watching
      sdetweil @banbutcher
      @banbutcher the words to the left of the [ needs to be in quotes, the page name/ id
        sdetweil @NicB72
        @NicB72 said in Could use some assistance setting up MMM-Carousel w/ Navigation and understanding the architecture:
        @sdetweil I don;'t understand. I am using the carouselID as described in the advanced config section of MMM-Carousel.
        looks like the id is supposed to be a number, by putting it in quotes it is a string.
        see this post
        https://forum.magicmirror.builders/topic/6640/could-use-some-assistance-setting-up-mmm-carousel-w-navigation-and-understanding-the-architecture/15?page=2
        also, make sure which mmm-carousel u are using
          banbutcher @sdetweil
                          slides: {
                              "Default":['clock', 'calendar_monthly', 'MMM-NetworkScanner', 'currentweather', 'weatherforecast'],
                              "Work":['MMM-google-route2'],
          		    "Traffic":['MMM-GoogleMapsTraffic'],
                              "Home":['clock', 'calendar_monthly', 'calendar', 'currentweather', 'weatherforecast', 'MMM-MyCommute', 'MMM-NetworkScanner',
          		    'MMM-COVID19-SPARKLINE', 'MMM-Spotify', 'MMM-GoogleFit', 'newsfeed'],
                              "Info":['clock', 'calendar_monthly', 'currentweather', 'weatherforecast', 'MMM-YouTube', 'MMM-NetworkScanner',
          		    'MMM-NetworkConnection', 'deluge', 'MMM-SystemStats'],
          like this? again all modules stacked on first and only page, also tried with numbers instead of words!
            @banbutcher I am not near my computer so have to wait til I can try.
            which module are you using, there are at least 3 different ones
              banbutcher
              ive used both barnabycolby and shbatm versions.
                banbutcher
                so i figured it out… using barnabycolby im not able to have the page rotation set to 0.
                MMM-GoogleAssistant works as intended along with MMM-GABackground.
                My config for barnabycolbys:
                            module: 'MMM-Carousel',
                                transitionInterval: 10000,
                		showPageIndicators: true,
                		showPageControls: true,
                                ignoreModules: ['alert'],
                                mode: 'slides',
                                slides: [
                                    ['MMM-google-route'],
                using shbatm i needed the position: 'bottom_bar' and now i can set the rotation time to 0 and control the slides with the arrow keys and MMM-KeyBindings, however it seems that when i use this version the MMM-GoogleAssistant does not display the correct background and therefore cannot use the new MMM-GABackground
                my config for shbatm:
                	    position: 'bottom_bar',
                                transitionInterval: 0,
                                mode: 'slides',
                                slides: {
                                    "Work":['MMM-google-route'],
                                    "Office":['MMM-google-route2'],
                                keyBindings: {
                                    enabled: true,
                                    map: {
                                        NextSlide: "ArrowRight",
                                        PrevSlide: "ArrowLeft",
                                        Slide0:    "Home"
                                    keyBindingsMode: "DEFAULT"
                hope this helps someone
                @Bugsounet @shbatm any idea why GAB will work with one carousel module and not another?
                  @banbutcher so, there were two problems
                  0 cycle time
                  and carouselId
                  I had my brain screwed on crooked for carouselId.
                  suppose you had multiple instances of the same module name in config.js, showing different things on different slides.
                  when u define the slides, u use the module ‘name’, but in this case, name is not enough.
                  so, in the module definitions themselves u add another unique identifier, carouselId: somestring. the value can be anything.
                  in their config:{} section, that is where carousel module will look for ‘carouselId’
                  in the slide definition, when u come to that module to be displayed, instead of putting the name in quotes, you need a little structure
                  { name: "module name", carouselId:"samevalue_added_to_module_config" } ,
                  that way the carousel module can tell which module instance should be shown
