    the top
    27 Posts 15 Posters 29.0k Views 17 Watching
    • F
      frankoucth
      Here is my first mirror
      What do you think
      0_1520102145801_IMG_1233.JPG 0_1520101787599_IMG_1210.JPG 0_1520102177507_IMG_1234 2.JPG 0_1520102201059_IMG_6616.JPG
      Mykle1M 1 Reply Last reply
      Reply Quote 9
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @frankoucth
        @frankoucth
        Well done! :-)
        • J
          jihefge
          Wow, nice work !
          Could you list used modules, please ?
          Thanks !
          • A
            adadws
            What is covered behind the mirror?
            mdf?
            How many millimeters is it?
            • F
              frankoucth
              Hi guys
              here is the list of my modules
              MMM-iframe
              MMM-Wunderground
              MMM-Snow for the winter
              MMM-trafic
              for the wooden plate under the glass I put the medium (mdf)
              of 10mm then stick the double-sided glass on top!
              A 1 Reply Last reply
              • A
                adadws @frankoucth
                @frankoucth
                Is mdf visible in the mirror?
                Have you painted mdf black?
                F 1 Reply Last reply
                  sispheor
                  Nice work !!
                  I see that you are french. Where did you buy the mirror?
                  Reply Quote 2
                  • F
                    frankoucth
                    bonjour
                    je suis de Grenoble et j’ai acheter le miroir dans une miroiterie
                    voici leur site https://miroiterie-sogemi.com/
                    Y 1 Reply Last reply
                    • F
                      frankoucth @adadws
                      @adadws
                      Hello
                      no mdf did not show (it’s really like a mirror) I painted the glass and not the mdf.
                        sispheor
                        I’m from Grenoble too! What a small world!
                        Nice! I’ll take a look to this shop! Thank you so much.
                        You should add this shop to other thread that talk about finding a mirror provider. Could be useful for other french guys.
                        Thanks again !
                        • A
                          adadws
                          look good!
                          What is the mirror transmittance and reflectance?
                            svenr
                            Very nice. Looks like the bathroom i would worry a bit about the humidity you dont think that the technic stuff could make problems later because of that?
                            • F
                              frankoucth @adadws
                              @adadws
                              Hello
                              I can not tell you for the choice I made tests for a better rendering
                              • F
                                frankoucth @svenr
                                @svenr
                                Hello,
                                no … after the tests, I have everything placed in a waterproof resin.
                                good ventilation of room water and it’s the ok !
                                • ceddirrC
                                  ceddirr
                                  Such a great work!
                                  magic mirror devient de plus en plus connu par chez nous :p
                                  Quick question, what kind of screen did you use, and which size is it? I would like to find a screen as slim as yours.
                                  • F
                                    frankoucth
                                    Hello
                                    my screen is a lcd of 80 cm of diagonal to take a minimum of thickness.
                                    • F
                                      Fonfon
                                      hi frank
                                      very good work !
                                      witch modules do you use for your ip camera ?
                                      please
                                        Simplearetenir
                                        Beau boulot !
                                        Quels sont les caractéristiques de ton miroir ? épaisseur ? transparence ? reflexion ?..
                                        • C
                                          calypsou1
                                          @frankoucth said in the top:
                                          slt svp jai un probleme de geolocalisation weather . ca veu dire que le api ne detecte pas ma region pour afficher le meteo (afrique du nord )
                                          • F
                                            frankoucth
                                            Hello
                                            to answer Simplearetenir
                                            the thickness of my magic mirror is 5 cm transparency is like a glass when the reflection I made tests to choose the one that suited me the best.
                                            and to answer calypsou1
                                            the best is to ask the question at https://github.com/RedNax67
                                            I’m in trouble to make A2DP on my magic mirror
                                            good week-end
