    Display Help
    25 Posts 3 Posters 13.1k Views 3 Watching
    • H Offline
      hnperkins
      Im sure this has been posted before and i have tried a few of the suggestions but Im at a loss atm as to how to use the entire screen. any help would be much appreciated
        Mykle1 Project Sponsor Module Developer @hnperkins
        @hnperkins
        Are you using a Pi?
        What resolution are you set to?
        Have you made any changes to any MM system files?
        • H Offline
          hnperkins
          yes i am using a pi2b i’ve tried the custom css with
          body {
             margin: 1px;
            height: calc(100% - 1px);
            width: calc(100% - 1px);
          i tried multiple margin sizes and height and width but it never comes down any further than what is in that screen shot
          i have
          disable_overscan=1
          hdmi_group=1
          hdmi_mode=16
          and my resolution is forced set to 1920x1080 60hz 16:9 after doing a
          tvservice -d edid
          Mykle1M 2 Replies Last reply Reply Quote 0
            @hnperkins said in Display Help:
            body {
            margin: 1px;
            I believe this should be
            body {
              margin: 1px;
              height: calc(100% - 2px);
              width: calc(100% - 2px);
            I don’t know about the other.
            • H Offline
              hnperkins @Mykle1
              @Mykle1 ok i will try that and see if it makes a difference. Could it be in the main.css? i just dont under stand why it wants to stay in the upper 1/4 of the monitor
                @hnperkins
                No, that belongs in the custom.css file. You should not be editing the main.css file unless you absolutely know what you are doing. That’s why I asked if you made any changes to the MM system files.
                • H Offline
                  hnperkins @Mykle1
                  @Mykle1 ok i see what you are saying. no i’ve not edited it. looked at it but not made changes. just the custom
                    @hnperkins
                    Someone will know how to solve your issue. I’m sure of it.
                    • H Offline
                      hnperkins @Mykle1
                      @Mykle1 hah i hope so, i’ve been going at this for about 3 hours now. not just the resolution issue but configuring modules and what not.
                        @hnperkins
                        Be patient. Someone will help you when they find this topic. Take your time with the modules. It gets easier with time
                          disable_overscan=1
                          hdmi_group=1
                          hdmi_mode=16
                          Just curious. Have you tried without this?
                          • H Offline
                            hnperkins @Mykle1
                            @Mykle1 yeah originally i just a clean boot and left everything stock from the install of noobs, that was just one of the things i had found to try via searching the forums and google
                              @hnperkins
                              ok, cool. And the custom res was because Raspbian did not support your res? Was there a res close to what you wanted?
                              • H Offline
                                hnperkins @Mykle1
                                @Mykle1 no i just tried the custom because on first boot it was exactly how it is in the picture so i tried the custom and nothing changed. i just tried again with an empty custom and its still doing the same thing. almost tempted to start all over from fresh
                                  @hnperkins
                                  Did you change the res in the raspi config at all?
                                  • H Offline
                                    hnperkins @Mykle1
                                    @Mykle1 yeah i tried that before i edited the hdmi settings in the config.txt
                                      stacywebb
                                      Just out of curiosity have you checked the settings on the actual monitor itself?
                                      I’ve had to adjust the settings on the monitor itself to achieve the desired resolution.
                                      Sometimes cycling between Wide - Normal - Full can make all the difference.
                                      You may need to reboot you pi after the changes (unless it detects automatically).
                                      • H Offline
                                        hnperkins @stacywebb
                                        @stacywebb i got it working finally. i ended up just reformatting the card and redoing everything from scratch. its now properly displaying but now having issues with a few modules lol
                                          @hnperkins
                                          Ok, well that’s good news.
                                          What modules and what problems are you having?
                                          • H Offline
                                            hnperkins @Mykle1
                                            @Mykle1 getting the mmm-pir-sensor to work right which might not be a module issue at all and then awesome alexa which is an amazon issue, not matter what i try i am unable to get a refresh token, i can get the access token using different methods i have found here but not the refresh token
