    MMM-NetworkConnection
    19 Posts 8 Posters 12.2k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @epi
      @epi
      Dependencies should be installed by running npm install in the MMM-NetworkConnection directory
      • E Offline
        epi
        Guys, can someone also make a simplified version? No need for internet speed metrics, just the ability to ping specific ip address and return as “internet is working” either “network down”?
        yawnsY 1 Reply Last reply Reply Quote 0
        • yawnsY Offline
          yawns Moderator @epi
          @epi said in MMM-NetworkConnection:
          Like this? https://github.com/sheyabernstein/MMM-connection-status
          • E Offline
            epi
            • Cr4z33C Offline
              Cr4z33 @slametps
              @slametps here is the Italian translation if you want to add it.
              	"NETCONN_CONNECTED": "Connesso ad Internet",
              	"NETCONN_NOTCONNECTED": "Nessuna connessione ad Internet",
              	"NETCONN_MILLISECOND": "ms",
              	"NETCONN_NA": "ND",
              	"TXT_NETCONN": "CONNESSIONE DI RETE",
              	"TXT_NETCONN_DESC": "mostra lo stato di connessione ad Internet"
              • Cr4z33C Offline
                Cr4z33 @slametps
                @slametps I had long read at speedtest readme however I couldn’t figure out what to edit to have a different server selected as best/favourite server.
                These are the details of the wanted server:
                server url="http://speedtestrm1.telecomitalia.it/speedtest/upload.php" lat="41.9000" lon="12.5000" name="Rome" country="Italy" cc="IT" sponsor="Telecom Italia S.p.A." id="3243" host="speedtestrm1.telecomitalia.it:8080"
                slametpsS 1 Reply Last reply Reply Quote 0
                • slametpsS Offline
                  slametps @Cr4z33
                  @Cr4z33 said in MMM-NetworkConnection:
                  Currently, the module is using default test server provided by speedtest-net node module. You should modify node_helper.js to add your desired test server.
                  You can find how to add the options, in here.
                  regards,
                  Slamet PS
                  • Cr4z33C Offline
                    Cr4z33 @slametps
                    @slametps that is where I looked at, but then I didn’t understand what file and what lines to edit.
                    The problem is that the default server looks to be located in the US therefore showing a very high ping and low speed results isn’t really what someone is expecting from the module. ;)
                    • Cr4z33C Offline
                      Cr4z33 @Cr4z33
                      @slametps at the end of the day I found finally some examples around, but everybody is reporting that setting a specific server somehow is not working (anymore?).
                      The line should look like
                      var test = speedTest({maxTime: 5000, serverId : "3243"});
                      however this causes an error in node_helper.js at MM loading and the screen goes black until I end MM itself. :confused_face:
