    MMM-NetworkConnection
    19 Posts 8 Posters 14.3k Views 6 Watching
    • E
      epi
      @Sandy2503 I changed to “-s” and still did not work.
      @Mykle1 I followed the installation guide, incl. the dependencies. I did not modify anything. I tried the module alone (all other cfg removed), still did not work for me.
      What is the installation folder for dependencies in your case?
      Mykle1M 1 Reply Last reply
      Reply Quote -1
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @epi
        @epi
        Dependencies should be installed by running npm install in the MMM-NetworkConnection directory
        • E
          epi
          Guys, can someone also make a simplified version? No need for internet speed metrics, just the ability to ping specific ip address and return as “internet is working” either “network down”?
          Y 1 Reply Last reply
          • Y
            yawns Moderator @epi
            @epi said in MMM-NetworkConnection:
            Like this? https://github.com/sheyabernstein/MMM-connection-status
            • E
              epi
              • Cr4z33C
                Cr4z33 @slametps
                @slametps here is the Italian translation if you want to add it.
                	"NETCONN_CONNECTED": "Connesso ad Internet",
                	"NETCONN_NOTCONNECTED": "Nessuna connessione ad Internet",
                	"NETCONN_MILLISECOND": "ms",
                	"NETCONN_NA": "ND",
                	"TXT_NETCONN": "CONNESSIONE DI RETE",
                	"TXT_NETCONN_DESC": "mostra lo stato di connessione ad Internet"
                • Cr4z33C
                  Cr4z33 @slametps
                  @slametps I had long read at speedtest readme however I couldn’t figure out what to edit to have a different server selected as best/favourite server.
                  These are the details of the wanted server:
                  server url="http://speedtestrm1.telecomitalia.it/speedtest/upload.php" lat="41.9000" lon="12.5000" name="Rome" country="Italy" cc="IT" sponsor="Telecom Italia S.p.A." id="3243" host="speedtestrm1.telecomitalia.it:8080"
                  slametpsS 1 Reply Last reply
                  • slametpsS
                    slametps @Cr4z33
                    @Cr4z33 said in MMM-NetworkConnection:
                    Currently, the module is using default test server provided by speedtest-net node module. You should modify node_helper.js to add your desired test server.
                    You can find how to add the options, in here.
                    regards,
                    Slamet PS
                    Cr4z33C 1 Reply Last reply
                    • Cr4z33C
                      Cr4z33 @slametps
                      @slametps that is where I looked at, but then I didn’t understand what file and what lines to edit.
                      The problem is that the default server looks to be located in the US therefore showing a very high ping and low speed results isn’t really what someone is expecting from the module. ;)
                      • Cr4z33C
                        Cr4z33 @Cr4z33
                        @slametps at the end of the day I found finally some examples around, but everybody is reporting that setting a specific server somehow is not working (anymore?).
                        The line should look like
                        var test = speedTest({maxTime: 5000, serverId : "3243"});
                        however this causes an error in node_helper.js at MM loading and the screen goes black until I end MM itself. :confused_face:
