    ReferenceError: Module is not defined...
    7 Posts 3 Posters 4.3k Views 3 Watching
    • justjim1220J
      justjim1220 Module Developer
      can someone please tell me what this error means and possibly how to fix it???
      Any help is MUCH APPRECIATED!!!
      “Life’s Too Short To Dance With Ugly People”
      Jim Hallock - 1995
      Mykle1M strawberry 3.141S 2 Replies Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @justjim1220
        @justjim1220
        I will tell you that I cannot see well enough to read your posted picture. If you would kindly copy any code you want to post and paste it in a code block, making it easily read by everyone, you’ll stand a better chance at receiving help.
        Starting MagicMirror: v2.3.1
        Loading config ...
        Loading module helpers ...
        Module helper loaded: MMM-NPMW
        Module helper loaded: MMM-BMW
        All module helpers loaded.
        You're using a full whitelist configuration to allow for all IPs
        Server started ...
        Connecting socket for: MMM-NPMW
        Starting node_helper for: MMM-NPMW
        Connecting socket for: MMM-BMW
        Starting node_helper for: MMM-BMW
        Launching application.
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @justjim1220
          @justjim1220 you have an issue here. you are trying to run node yourmodule.js. First of all in MM it is used in the browser, so no node environment. Second the Module variable is nothing that comes from node or javascript itself it is a global variable for the MM thet gets placed in the browser too.
          What are you trying to achieve? Unit testing the module isolated. Run it without the MM project (does it make sense)? Why you are not setting it in the modules folder in MM and configure it in the config file to test it?
          • justjim1220J
            @Mykle1
            @strawberry-3-141
            First of all, I am pretty much a newbie to this module creation… This is my first attempt.
            I am using Visual Studio Code, and I was under the impression I could run a debug on the module itself. Sorry, My bad.
            What I’m getting from your replies, I should be inputting the whole MM project into the VS code environment, then run debug???
            Furthermore, I was having major issues trying to get the module to run on MM, then realized I needed to create it into a repository and do the git clone and install with the repository. I didn’t do that, I was just trying to create it and add it to my modules directory using the MM template (first item listed in the 3rd party modules).
            So, now, after figuring out that part, I have created a repository, went through the channels to add it to my MM, and now I’m getting it to show up on the mirror, it just isn’t playing.
            This is what it looks like now…
            And this is the npm results while MM is running…
            Starting MagicMirror: v2.3.0-dev
            Loading config ...
            Module helper loaded: MMM-RandomYouTubePlayer
            Module helper loaded: MMM-NOAA
            Module helper loaded: MMM-CalendarExt
            Server started ...
            Starting module: newsfeed
            Connecting socket for: MMM-RandomYouTubePlayer
            Starting module helper: MMM-RandomYouTubePlayer
            Connecting socket for: MMM-NOAA
            Starting module: MMM-NOAA
            Connecting socket for: MMM-CalendarExt
            Create new news fetcher for url: https://news.google.com/news/rss/local/section/geo/Bethany,%20MO,%20United%20States/Bethany,%20Missouri?ned=us&hl=en&gl=US - Interval: 300000
            I really do appreciate everyone’s input and getting me back into the coding realm! :grinning_face_with_smiling_eyes:
            Jim Hallock - 1995
            • justjim1220J
              OK, so if anyone out ther feels like it, here is my .js code…
              Module.register("MMM-RandomYouTubePlayer", {
              	defaults: {
              		playlistId: "PLl_KM23gznEAZW-INW8ty4QNaHH8JCnNW",
              		listType: "playlist",
                      height: 480,
                      width: 720,
                      autoplay: true,
                      disablekb: true,
                      enablejsapi: true,
                      color: "red",
                      fs: false,
                      volume: 100,
                      cc_load_policy: true,
                      controls: false,
                      showinfo: false,
                      rel: false,
                      modestbranding: true,
                      loop: true,
                  getDom: function() {
              		var scriptContainer = document.createElement('script');
              		// var playlistId = (this.config.playlist_ID);
                  	function onYouTubeIframeAPIReady() {
              			player = new YT.Player('player', {
              		    height: '480',
              		    width: '720',
              		    events: {
              			'onReady': onPlayerReady,
              			'onStateChange': onPlayerStateChange,
              		var playlistArray;
              		var playListArrayLength;
              		var maxNumber;
              		var oldNumber = 0;
              		var NewNumber = 0;
                  	function newRandomNumber() {
              			oldNumber = NewNumber;
              			NewNumber = Math.floor(Math.random() * maxNumber);
              			if (NewNumber == oldNumber) {
              			    newRandomNumber();
              			} else {
              			    return NewNumber;
                  	function onPlayerReady(event) {
              			player.loadPlaylist({
              			    list: this.config.playlistId,
              		var firstLoad = true;
                  	function onPlayerStateChange(event) {
                  		console.log(event.data);
              			if (event.data == YT.PlayerState.ENDED) {
              			    player.playVideoAt(newRandomNumber());
              			} else {
              			if (firstLoad && event.data == YT.PlayerState.PLAYING) {
              			    firstLoad = false;
              				playlistArray = player.getPlaylist();
              				playListArrayLength = playlistArray.length;
              				maxNumber = playListArrayLength;
              				NewNumber = newRandomNumber();
              		wrapper.appendChild(scriptContainer);
              		var TempDiv = document.createElement('div');
              		wrapper.appendChild(TempDiv);
              		TempDiv.setAttribute("id", "player");
              		var tag = document.createElement('script');
              		wrapper.appendChild(tag);
              		tag.src = "https://www.youtube.com/iframe_api";
              		var firstScriptTag = document.getElementsByTagName('script')[0];
                      wrapper.appendChild(firstScriptTag);
              		firstScriptTag.parentNode.insertBefore(tag, firstScriptTag);
              		var player;
                      var done = false;
              		wrapper.innerHTML = "<iframe width=\"" + this.config.width +"\" height=\"" + this.config.height + "\" src=\"https://www.youtube.com/embed/?" + this.config.listType + "&" + this.config.playlistId + "frameborder=\"0\"></iframe>";
              		return wrapper;
              Any and all hints, pointers, or input are very welcome and encouraged!!!
              Jim Hallock - 1995
              strawberry 3.141S 1 Reply Last reply
              • strawberry 3.141S
                @justjim1220 first you should remove your calendr link from the logs, everyone is able to download your private calendar.
                If I remember correctly that youtube has settings to allow/prevent embedding maybe you have to change something there, as the player is there but the video not playing. Maybe it’s also just some videos that are not embedable.
                justjim1220J 1 Reply Last reply
                Reply Quote 1
                • justjim1220J
                  justjim1220 Module Developer @strawberry 3.141
                  @strawberry-3-141
                  Thanks for answering…
                  My calendar link is there, but my password is not. It does say private, but it actually is public, so anyone can see it, nothing too personal ever gets put on there anyway. :smirking_face:
                  I can get a YT player to work on the MM, I’m just trying to figure out how to shuffle the list so it doesn’t start from the first song every time i gets loaded. And, if it’s just the video it has problems with, it gives a different error and will go to the next video. So, I know its not that either.
                  Jim Hallock - 1995
