    MMM-Temperature/Humidity Module (DHT11, DHT22 and AM2302 sensors.)
    34 Posts 11 Posters 37.6k Views 10 Watching
    • H3L1o150H Offline
      H3L1o150
      @yawns Tanks for the help
      maybe i’m wrong in code. with me show a white screen
      pskP 1 Reply Last reply Reply Quote 0
      • pskP Offline
        psk @H3L1o150
        @H3L1o150 currently, to define the pin to which sensor is connected, you need to edit the node_helper.js file ind MMM-Temperature-Humidity directory and edit line number 12.
        var dht = new rpiDhtSensor.DHT11(2); to var dht = new rpiDhtSensor.DHT11(21);
        you can leave the config as
        			module: 'MMM-Temperature-Humidity',
        			position: 'bottom_right',
        				refreshInterval: 10000,
        				temperaturePrefix: "Room temperature: ",
        				temperatureSuffix: "°C",
        				humidityPrefix: "Humidity: ",
        				humiditySuffix: "%"
        guess this needs to be improved in future release… :D
        Note from admin: Please use Markdown on code snippets for easier reading!
        P.S.K
        • H3L1o150H Offline
          H3L1o150
          Tanks @psk
            jsyzthz
            i found MMM cannot auto startup if use it. because it must be run with sudo. but i don’t know how to run sudo with ‘DISPLAY=:0’? @psk
            • BangeeB Offline
              Bangee Module Developer
              @jsyzthz checkt this out: https://forum.magicmirror.builders/topic/738/mmm-dht22-humidity-and-temperature-module
              • pskP Offline
                psk @jsyzthz
                @jsyzthz Unfortunately neither did I have any luck executing with sudo while using ‘DISPLAY=:0’ .
                For auto start I used PM2.
                This is my mm.sh file
                cd ~/MagicMirror
                DISPLAY=:0 sudo npm start
                P.S : I haven’t yet tried this alternative by Bangee. But it sure looks promising in this scenario where we need the mirror to start from ssh(or Terminal) while specifying the display device.
                If i come across any workarounds, I’ll update.
                Cheers.
                P.S.K
                  jsyzthz
                  @psk , when i execute your command in my pi3 from putty. will get below error.
                  0_1476980028924_upload-94e2d7d2-b3a1-493a-a093-7ac8645113c3
                    d3r
                    I’m going to order the dht-22 soon. I was reading about the sensor set up and most guides mention using a resistor. Do you guys have one in your set up?
                    • pskP Offline
                      psk @d3r
                      @d3r Dht 22 and 11 series doesnt require one :)
                      PS: Just saw the post.Was out of town for two weeks…
                      P.S.K
                      yawnsY 1 Reply Last reply Reply Quote 0
                      • yawnsY Offline
                        yawns Moderator @psk
                        @psk
                        That depends on the sensor you buy. If you use a sensor with 4 pins you need the resistor. If you use the sensor with 3 pins mounted to a circuit board you don’t need the resistor.
                        • 3 / 4
