    Microphone/MMM-voice Help
    31 Posts 7 Posters 15.3k Views 7 Watching
    • T Offline
      tnp0327
      Hi everyone!
      Absolute newbie with no real coding background here so thanks in advance for the patience and help!
      So I’ve built a MM for my wife and I’ve also installed google AIY so that it functions as both a MM and google assistant. I would also like to be able to use the microphone for MMM-voice and everything appears to have installed properly, however, when I load MM it will not change from “Initializing”. I have a feeling that this is because the microphone is only “ON” when I am running one of the AIY demo.py’s AND giving the command “Hello, Google” or OK, Google but, again, I am a noob and could be completely wrong. Do you have any advice for getting the PI/MM/MMM-voice to initialize the microphone/voice-HAT?
      Thanks in advance!
        Mykle1 Project Sponsor Module Developer @tnp0327
        @tnp0327
        I could be wrong (I often am) but I don’t think the microphone can be shared. It’s one module or another.
        • T Offline
          tnp0327
          Thanks for the response, @Mykle1 . @strawberry-3-141 asked me to debug and I added debug:true to the config file but am not sure where the debug log data is stored. Any help on finding the debug data?
          It almost hurts to ask that question :(
          Thanks!
          S strawberry 3.141S 2 Replies Last reply Reply Quote 0
            sdetweil @tnp0327
            @tnp0327 minimize the mirror window (alt-spacebar, n) and the terminal windows used to start the mirror will be shown… the debug is in that window…
            least thats how I do it!..
            this debugs the node_helper
            ctrl-shift-i will open the mirror debug window (select console tab) this will show the module level debug
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @tnp0327
              @tnp0327 the file that gets generated is located at modules/MMM-voice/debug.log
              • T Offline
                tnp0327 @strawberry 3.141
                @strawberry-3-141 here is a snapshot of the directory. I do not see a debug.log file. Do you know why this could happen?
                  @tnp0327 can you show me the mmm-voice part of your config js
                  • T Offline
                    @strawberry-3-141 I originally had it in the config section but moved it up below “position”. However, I am still not seeing a debug.log file. I rebooted and still nothing.
                      @tnp0327 it needs to be in the config section
                      • T Offline
                        @strawberry-3-141 thanks! I moved it to the config section.
                        I still do not see a debug.log file.
                        When I run MM, the MMM-voice area (bottom left) says Initialising… and underneath that it says undefined.
                          sdetweil @tnp0327
                          have u restarted the mirror a few times, without reboot?
                          the sound process does NOT get restarted…
                          get back to the commandline and do
                          ps -ef | grep pocket
                          and then kill that process so it can be restarted…
                          or reboot…
                          i created this little script for a prior mirror runtime that I use here too
                          #!/bin/bash
                          ps -ef | grep pocket | grep -v "color=auto" | awk '{print $2}' | xargs sudo kill -9
                          ps -ef | grep node | grep -v "color=auto"  | awk '{print $2}' | xargs sudo kill -9
                          • T Offline
                            tnp0327 @sdetweil
                            @sdetweil I have restarted the MM process and rebooted the PI - still no debug.log file.
                              sdetweil @tnp0327
                              @tnp0327 can u minimize the mirror and look at the console log of the terminal window… maybe there is some other error…
                              minimize = alt-spacebar, n
                              • T Offline
                                tnp0327
                                @sdetweil @strawberry-3-141 so I did not find a debug file but was able to follow the instructions to look at the console log and the only message I am seeing regarding MMM-voice is:
                                Starting module: MMM-voice MMM-voice.js:82
                                MMM-voice is waiting for voice command registrations. MMM-voice.js:85
                                  sdetweil @tnp0327
                                  @tnp0327 before the modules is the startup of the node_helpers… if u can scroll back up the console window, you might find something else…
                                  have u tested to make sure the mic is working? with the rec command?
                                  rec somefile.wav
                                  on the bottom of the console window should be a meter like bar that moves when u speak…
                                  then you can control-z out of the rec command and then play somefile.wav to see how it sounds…
                                  • T Offline
                                    tnp0327
                                    OMW to work now - will run it again later and update with my feedback. Thanks for the help so far.
                                      Abhilash1368 @tnp0327
                                      @tnp0327 I am going through same thing,it displays mic flashing symbol and just says initialising and undefined at bottom(if degug:true).Did you resolve it?please let me how to make it work?
                                        strawberry 3.141 Project Sponsor Module Developer @Abhilash1368
                                        @abhilash1368 do you have content in your debug log file?
                                          Abhilash1368 @strawberry 3.141
                                          @strawberry-3-141 I don’t see any content,but its working now.Initially I have my own custom twitter module loaded along with MMM-voice(my twitter.js is not modified yet to support MMM-voice). Once after making changes to my twitter.js according to “Hey Lucy” documentation to receive voice notifications,then it is started working. Thanks
                                          • richland007R Offline
                                            richland007
                                            @strawberry-3-141 Ok so i have a very similar situation i have AlexaPi (and MMM-AlexaPi for visual feedback) and want to use MMM-voice and Hello-Lucy. I have 2 USB microphones (a webcam that i talk to AlexaPI and a USB sound card that i want to use for MMM-voice)
                                            On the config.js i have assigned microphone id of 2 for MMM-voice ( arecord -l and the install of MMM-voice show that alsa as 0 USB webcam as card 1 and USB sound card as card 2)
                                            when i start magic mirror MMM-voice says “initializing” than briefly “Waiting for module commands” than settles on “error”
                                            My questions are:
                                            1. and i am pretty sure i have an answer for this is that AlexaPi and MMM-voice can they use the same mic or not … most likely not .
                                            2. why isn’t using microphone #2 straight forward do i have to twitch anything on alsa config, etc will pulse audio be better and what is the difference ?? how do we mitigate this problem??
                                            I have tested and confirmed that both usb microphones work when they are plugged each by themselves but not when they are both simultaneously plugged in only the webcam would record … i am not sure if i am putting the right parameter here “arecord hw:1,0 -d 10 /tmp/test-mic.wav”
                                            Please any help will be greatly appreciated
                                            Denis
